July 06, 2008, 09:15:27 AM
| | |-+  *Offset* Master Cylinder Adapter
Author Topic: *Offset* Master Cylinder Adapter  (Read 415 times)
Two Lane
« on: April 03, 2008, 10:40:21 AM »
Am sure everyone's familiar with the *offset* MC adapters for A-bodies to be used when installing the later model aluminum MCs.
(Not to be confused with the much more common non-offset adapter/spacer allowing use of the later MCs)
It was originally made to allow more VC clearance on Hemi A-bodies, but also helps with clearances on BB A-bodies.
(It is sold by MOPAR, Mancini, & AR.)
Is anyone here running one?
Any issues with the brake pushrod? (length, angle, etc) -------------?HuhHuhHuhHuhHuh
Did your original brake pushrod work?
Or did it require the adjustable pushrod?
Because of the slight lateral offset of the MC, does this resulti in any issues for the stock pushrod?
*Appears* all you need is a late-model MC, and the offset adapter.
Is it actually that easy?
How did your install go? -------------------------------- Thanks!
mopowers
Re: *Offset* Master Cylinder Adapter
« Reply #1 on: April 03, 2008, 10:54:11 AM »
I don't know the answers to your question, but I do know Master Power Brakes has adjustable pushrods for ~$30.  Good people to deal with also.
2006 Dakota
Two Lane
« Reply #2 on: April 03, 2008, 11:06:15 AM »
Birdius Rapidus
« Reply #3 on: April 03, 2008, 03:19:23 PM »
I think Mancini sells them. I made my own from aluminum. This is the firewall side.
Bill_Reilly
Administrator
White Haven, PA
« Reply #4 on: April 04, 2008, 08:30:52 AM »
The AR version moves it over 7/8". You basically move the pushrod to the other side of the pedal, but you need to add about 3/4" to the length, so an adjustable pushrod is needed.
...I also started carrying a 2" offset version that's popular with the SS hemi cars - you can pull a hemi valve cover without removing the master - this one requires a little fab work at the pedal though.
A13Dart
Minnesota
« Reply #5 on: April 05, 2008, 11:39:23 AM »
Master Power has the best adjustable brake push rod on the market.  Imho.
JohnDirt
Impossible is Nothing
« Reply #6 on: April 05, 2008, 11:47:37 AM »
I don't know if this would work as good for hemis, but we just moved the master cylinder up, used the top bolts for the bottome of the ms, and re drilled for the top, didn't have to do anything special or spemd any extra money, other than two bolts and nuts
Two Lane
« Reply #7 on: April 28, 2008, 11:15:13 PM »
This thread helped greatly in finishing that particular project with the right parts on hand beforehand with zero drama & no surprises!!
(Really helps to get these kinds of Qs answered *before* venturing into
new arenas,and that's what we/you accomplished together via this thread.)
THANKS from our garage to yours for each & every helpful reply! ------------------- Smiley
dusterdarryl
« Reply #8 on: May 01, 2008, 07:01:15 AM »
how did you get on for a rod?
