Topic: Is my car a Formula S ? (Read 552 times)
joesnow
I have a '65 Barracuda v-8 4 speed car. The motor and trans are gone. How do I tell if it is a formula s car? Thanks.
LILBLUE65
Formula 'S' option included Commando 273, Rallye suspension package, special Goodyear Blue Streak tires and tachometer. I got that form my 65 pamphlet. Try the early Val. Bar. site. They might have more info.
Rob
I believe the tach was Formula S only (at least what has always been indicated). The rear valence should have a rectangular cutout for the large single tip. The lower control arms should have sway bar tabs and there should be a sway bar. I don't know what codes to look for on the fender tag. The VIN won't tell you.
LILBLUE65
Barracuda's Accessory Groups ...
BASIC GROUP
Radio-Transaudio AM Push-Button-with antenna'. Windshield Washer and Variable-speed Wipers. Mirror-outside left (manual) Mirror-Day/Night-inside rearview.
FORMULA "S" PACKAGE (N.A. with Performance or Sport group)
Commando 273 8-Cyl. engine-4-bbl. carburetor Suspension Package- H. D. rear springs, H.D. torsion bars and sway bar. Shock Absorbers-Firm Ride-front and rear Tachometer 6.95 x 14"' Special Blue Streak tires Heavy-gauge, wide-rim 14" wheels 14" Wheel Covers-bolt-on design
PERFORMANCE GROUP (N.A. with Formula "S" Package)
Commando 273 8-cyl. Engine-4-bbl. carburetor Suspension Package- H.D. rear springs, H.D. torsion bars, and sway bar. Power Brakes
SPORT GROUP (N.A. with Formula "S" Package or 6.95 x 14" tires)
Steering Wheel-3-spoke simulated wood grain. Wheel Covers-bolt-on wheel design. Tires, Whitewall- 6.50~x 13"'-6-cyl. 7.00 x 13"'-8-cyl.
Hope this helps. Rob
DonC1965
From the www.earlycuda.org website: "Want to know if it's a Formula S? On the fender tag of a 65 Barracuda, look for the 'ABC'.... under the AB will be a '31' for the 273 4bbl 235hp engine. Under the C will be a '2' for the formula "S" package. The car should also have a tach in the dash...." Don
joesnow
I just checked the tag under AB is 30 under DE is 35 so i am guessing it is a 273 2 bl 4 sp Thanks.
pishta
The tach is a giveaway. The stripe is not, also count the number of leafs in the rear, I think the S has 5 and of course the torsion bar mounts.
