July 09, 2008, 08:16:09 AM
| | |-+  Wiper Seals?
Author Topic: Wiper Seals?  (Read 180 times)
68dartproject
Wiper Seals?
« on: April 10, 2008, 02:04:56 PM »
Hi, I have a 68 dart and I know the wiper seals need to be replaced, but I dont know how.  Did a search and found people talking about them, and that it was a PITA but none said how.  Thanks guys.
jet-taz
Re: Wiper Seals?
« Reply #1 on: April 10, 2008, 04:31:01 PM »
schumacher engine mounts  sells them,you need to take the wiper linkage off and take the pivots down, the seal the fit over the wiper pivots they are really tight fitting put a little grease will help. they also includes gaskets for the base.cost around 12 for a set jet-taz
68dartproject
Re: Wiper Seals?
« Reply #2 on: April 10, 2008, 04:59:47 PM »
Ok, so am I correct in thinking that these new seals will cover the hole on the body where the wipers come out?  If not how do I actually get underneath the wipers.
jet-taz
Re: Wiper Seals?
« Reply #3 on: April 10, 2008, 07:49:03 PM »
they should come out under the dash board. there 2 nuts holding each pivot and clips on the linkage and wiper motor
smallbigblock
Re: Wiper Seals?
« Reply #4 on: April 11, 2008, 10:36:06 AM »
Here is a pic I took of the driver side.  Hope it helps
I should have left it alone
Re: Wiper Seals?
« Reply #5 on: April 11, 2008, 10:54:43 AM »
Someone on the site made a set using a couple of valve stems. Might try that.  Grin
Duster440
Blasphemous custom Duster
Re: Wiper Seals?
« Reply #6 on: April 11, 2008, 01:22:54 PM »
Yes, the new seals will cover the holes in the body, amongst other things. More importantly, they prevent water from running down the shaft and dripping on your feet. The lower gaskets, as mentioned, on the cowl plenum is the other half of the equation. Adding a zerk fitting to the pivot provides additional lubrication and insurance against water passage.
I've got pics here. Scroll down the page: http://www.70duster440.com/misc.html
