Topic: 67 Dart,13"tire's narrowed rearend an 3"loweing block's (Read 451 times)
blasphemous
Looks good, that's alot of meat in there.
jbarker
Looks good! Do you have a pinion snubber or anything else to help traction? I'm putting together a car with about 500 hp, Dana 60, 2 inch lowering blocks, snubber, HD leafs. Some people tell me the spring wrap with lowering blocks will be terrible. Obviously this is not a problem for you! Nice job. -Jay
Capt Jack
Ive constantly heard the same, but have never used drop blocks on a car. these look almost like the blocks themselves have been welded to the housing, as I dont see a regular spring saddle there.
rharveysr
What is the reason for the lowering blocks?
Rick
Womanator
No pinion snubber mopar chassie book says not to run them, I have 3" lowering blocks. The blocks have been welded to the housing. The best 60ft time with the smaller tires was 1.58 sec. Reason for the lowering blocks is I dont like the back end sitting in the air, and should get better weight transfer. Also the lower the car is to the ground the less air flow there is under the car. This year more horsepower  E "His son"
The 1
What type of lowering blocks are those steel or aluminum and do they come in a kit?
" I'm ready to kick the tires and light the fires Big Daddy!!"
Womanator
Custom made steel blocks made by chassis shop, welded on in a jig
rharveysr
I thought that was the reason...
Rick
The 1
Thanks for the info.
Womanator
I'll get the car out today or tomorrow and take a picture of the stance and you'll see the reason for the lowering blocks.just sits leveler.marv
