August 30, 2008, 09:56:37 AM
| | |-+  neutral safety switch
Author Topic: neutral safety switch  (Read 262 times)
grudd440
« on: April 13, 2008, 01:47:22 PM »
how would u wire up a neutral safety switch with a 727 trans and a push button starter switch?
Re: neutral safety switch
« Reply #1 on: April 13, 2008, 02:28:52 PM »
are you using the original wiring?
« Reply #2 on: April 13, 2008, 09:29:34 PM »
the plug on the trans detects when you are in park or neutral.
isn't wiring the shifter redundant at that point?
i just run a wire from the trans to the starter relay.
                moparts can kiss my ass  moon
Prodart
« Reply #3 on: April 13, 2008, 09:38:41 PM »
Through the neutral switch on yhe 'Output' side of the starter switch. In other words power into starter dash switch. Then into neutral switch. Then from neutral switch to Starter. Grin
« Reply #4 on: April 14, 2008, 12:45:57 AM »
Are you still using a starter relay? If so West is right........
« Reply #5 on: April 18, 2008, 04:12:56 PM »
The STD neutral safety switch sends a NEG signal to the starter relay when it is in Park or Neutral. You can use any relay to trigger the system, not necessarilly the OEM one. The Safety switch just sends one half of the signal needed to fire the relay. The key sends the other.
