October 06, 2008, 10:34:16 PM
| | |-+  Anyone mini-tubbed a space duster?
Author Topic: Anyone mini-tubbed a space duster?  (Read 491 times)
68snewpy
« on: April 15, 2008, 11:29:53 PM »
I'm looking at doing this but there are some special brackets on the space dusters (fold-down rear seat) that must be dealt with.  I'm not going to use the back seat so should I just cut the brackets off and install a cross brace like "normal" cars.  I'm not planning a cage yet.  Some pics would be great.
73swinger
Blackstock, Ontario
Re: Anyone mini-tubbed a space duster?
« Reply #1 on: April 16, 2008, 09:41:00 AM »
 Huh
« Reply #2 on: April 16, 2008, 10:34:41 AM »
i would install frame connecters now,then rip out the inner junk.
68snewpy
« Reply #3 on: April 16, 2008, 12:02:52 PM »
I'm thinking more along the lines of supporting the upper structure of the car (roof and rear quarters).  Without the bracing couldn't it become a little floppy?  I'm not yet convinced that frame connectors provide much frame twisting support either, physics tells me that a boxed structure is stiffer than any 2-dimension frame could ever be.  Take a bare flat-deck trailer frame and shake one corner, you'll see what I mean.
super70bird
« Reply #4 on: April 16, 2008, 04:30:00 PM »
If these are the brackets you're referring to (see pics) they are pretty flimsy and only there to add a bit of strength to the cargo area between the back seat and trunk panel.  Notice the lovely factory welds Smiley  I'm putting a roll bar in mine (keeping the fold down seat) and I'm going to be cutting mine for the rear struts (cutting where the square is marked).
CudaDon65
« Reply #5 on: April 16, 2008, 04:49:03 PM »
Thats the same in my 1965 barracuda. I cut the welds on the bracket and split the tubs and moved the whole thing.
68snewpy
« Reply #6 on: April 19, 2008, 12:34:16 PM »
Thanks for the responses.
If I want to race this car (NHRA rules) do I need to seal the trunk off for a relocated battery?
Anybody have finished pictures of a space duster setup this way?
« Reply #7 on: April 19, 2008, 01:26:10 PM »
no,but it does have to be in a box
68snewpy
« Reply #8 on: April 19, 2008, 06:31:10 PM »
I've read that but what do they mean by having the box vented to the outside?  Can you just drill a hole through the floor?  I certainly don't want a vent line drilled through my quarter panel or deck lid.
sbmopar
« Reply #9 on: April 22, 2008, 07:41:13 PM »
If you run a new sytle optima or similar spiral gel battery, I believe you don't even need a box due to no vent or acid in the battery bat.  Depending on how fast you go, you may not get bothered. I have been running my car with a standard battery in a box in the trunk of my Dart and have never been bothered. I don't even run a battery cut off switch. Sooner or later I will get caught though.
