October 06, 2008, 07:43:40 AM
| | |-+  Roll cage paint prep
Author Topic: Roll cage paint prep  (Read 331 times)
« on: April 17, 2008, 10:02:31 PM »
How would you guys clean up minor surface rust on a cage before paint?  Scotchbrite? Steel wool and WD40?
Re: Roll cage paint prep
« Reply #1 on: April 17, 2008, 10:28:22 PM »
I just used 400 grit 3M Wet-or-Dry sandpaper without oil.  If you use WD-40 and get it into the weld joints you'll play hell getting it all cleaned out of there.  WD-40 is good for causing "fisheyes" in paint.  We used to shoot to kill, anybody that even possessed a can of WD-40 in our paint/body shop when I did paintwork for the local Dodge dealership.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
« Reply #2 on: April 17, 2008, 10:37:44 PM »
NO WD-40........400grit paper will work, black biscuit disc for the welds if the paper doesnt get all surface rust out of the welds
sunsetdart
us4ever365@hotmail.com
« Reply #3 on: April 18, 2008, 07:46:37 AM »
Those sanding sponges Home Depot sell for doing sanding in the home work well. They contour to round surfaces without leaving finger marks.
rharveysr
« Reply #4 on: April 18, 2008, 10:02:08 AM »
I used 400 grit and once that was done I wiped it down with lacquer thinner to get it all clean before the primer was put on...I made sure that the bars were clean before the primer was put on..
« Reply #5 on: April 18, 2008, 10:29:24 AM »
Thanks guys.  Looks like 400 grit it is then.  Is it okay to just use a wire wheel around the joints and on the weld?
« Reply #6 on: April 18, 2008, 10:48:44 AM »
Yup, just don't hit them with a hard wheel.
« Reply #7 on: April 18, 2008, 02:31:05 PM »
rharveysr
« Reply #8 on: April 18, 2008, 04:57:34 PM »
That is what I used also...
B-onefan
Wild West Texas
« Reply #9 on: April 22, 2008, 11:59:05 AM »
Use some body shop Metal Prep and a scotch brite pad after the 400 dry and before you prime. Be sure to use gloves as this is a weak acid solution.
73 Duster
74 Duster
76Duster
67 Barracuda
68 Barracuda
68 Dart
69 Dart
72 Dart
78 Trail Duster
1999 Ram 1500 Sport QC 4X4
