July 04, 2008, 11:44:53 PM
| | |-+  Fiberglass light weight hood spring question
Author Topic: Fiberglass light weight hood spring question  (Read 152 times)
Crazy68Dart
« on: April 18, 2008, 10:45:04 AM »
I have an AAR bolt on hood and got a set of springs from a guy here, DangerDawg I think??
Anyway, do I need to preload these springs on the hinges, and if so, how do I do this safely?
Thanks.
Duster440
Blasphemous custom Duster
Re: Fiberglass light weight hood spring question
« Reply #1 on: April 18, 2008, 12:06:34 PM »
I got mine, which were modified originals, from Herb. I don't know if Atomic Dog's are different or not. I just put the hinges on the pins, slid the spring on, and then hooked the end on the pin using a pair channel lock pliars. You want the minimum amount of preload or tension possible. A couple of spot welds on the center stud will keep it from sliding off.
Preston H. - www.70Duster440.com
DART VADER
« Reply #2 on: April 18, 2008, 01:46:15 PM »
I took my springs completely off. I just put the springs in a vise to keep tension on it. Then I popped it off the pin and slowly opened the vise. After that I just used a hammer and chisel to pull it off the post.
DV
bbd sign tried and true
Crazy68Dart
« Reply #3 on: April 18, 2008, 04:29:59 PM »
Man, I must be mental or something... I need to look at them again.
