July 24, 2008, 12:18:27 AM
| | |-+  Front Coil Overs
Author Topic: Front Coil Overs  (Read 309 times)
mopowers
Front Coil Overs
« on: April 18, 2008, 12:03:24 PM »
I'm contemplating ditching my torsion bars and using coilovers instead.  Besides header clearance, are there any other benefits to going this route?
Do coilovers provide more front-end movement?
2006 Dakota
lake worth, florida
55robert@bellsouth.net
Re: Front Coil Overs
« Reply #1 on: April 19, 2008, 09:06:20 AM »
actually there is less movement, about 4" or so but will have 12 way adjustablilty.
mopowers
« Reply #2 on: April 20, 2008, 05:19:00 PM »
So, the benefits seem to be header clearance and adjustablility.  Anything else?
Since I have to build a custom set of headers regardless, that shouldn't be a problem.  Plus, there are plenty of good adjustable shocks available and height is easily adjusted w/ a torsion bar set-up.
I guess I just made my decision.
2006 Dakota
Dono
Want what you have..........
« Reply #3 on: April 22, 2008, 12:07:50 PM »
YOu ever have one of those 30+ year old Tbar adjuster bolts strip out of the block and the fender hit the ground.......Just thank the lord your not under it.  Coil over on the front for me.
rharveysr
« Reply #4 on: April 22, 2008, 12:26:52 PM »
what is all involved in doing the coil overs in the front?  Dont have the extra $$$$ for one of the RMS complete kits
Rick
mopowers
« Reply #5 on: April 22, 2008, 12:41:23 PM »
Rick
Tubular upper control arms $300
Coil-over shocks (single adjustable) w/ upper stud mounts $500
The shock mount should be tied into the front cage strut.  The lower control arm also needs to be slightly modified so it doesn't fall out.
I probably won't end up doing it though, because I want the most front end travel possible.
2006 Dakota
