October 07, 2008, 12:37:46 PM
| | |-+  8.25 backing pads & brakes
Author Topic: 8.25 backing pads & brakes  (Read 183 times)
MoPar_or _NoCar
« on: April 19, 2008, 10:36:23 PM »
Will the backing pads and brakes from an A body 8.25 work on an A body 8.75?
jbarker
Re: 8.25 backing pads & brakes
« Reply #1 on: April 20, 2008, 08:52:51 AM »
Yes, but be sure to take everything off the donor car.  The backing plates have the same bolt pattern.  The e- brake cable will slip in fine.
-Jay
Dono
Want what you have..........
« Reply #2 on: April 22, 2008, 05:07:11 PM »
Better getting the parts off a Dakota.  Midd 80's will do and you get bigger brakes.  All the parts will bolt right on.
« Reply #3 on: April 22, 2008, 05:16:45 PM »
Not if the a-body rear still has a-body axles redrilled or not.
« Reply #4 on: April 23, 2008, 01:32:00 PM »
  I've been through this a few times. There are three different spacings between the axle's flange and the housing's flange. Your donor's measurement MUST match the axle you are trying to retro fit to. A body 8 3/4 is one size, which is different from the STD B body, which is different from the third which escapes me right now. But as I said if the two you are going to use parts to and from match, there will be no problems. For example: we took the brakes 11 x 3 off of a Cordoba with a 9 1/4 and used them on an early (65 non tapered axle) B body 8 3/4. Did the same with a (76 4x4) truck axle 9 1/4 to a replacing (71 2WD) truck 8 3/4. Swung out the brakes and swung in the 8 3/4 and bolted up the brakes without cracking a line.
