August 30, 2008, 03:42:15 AM
| | |-+  torsion bar crossmember
Author Topic: torsion bar crossmember  (Read 406 times)
« on: April 20, 2008, 02:42:32 AM »
Anyone replaced theirs with a solid piece of steel tubing. My crossmember is all rusted up and the one mount is rusted away so I'm doing a coil over suspension up front so I don't need my torsion bar mounts. Anyone ever done it? I can buy a piece of 2"x3" .083" wall tubing with a 3.5 inch drop crossmember from competition engineering off summit for about 60 bucks but I'm unsure if that would give me enough bend around the trans and clear my floorpans.
-46 Fargo
Saint Paul, MN
Re: torsion bar crossmember
« Reply #1 on: April 20, 2008, 10:46:57 AM »
If you are switching to coilovers you really wouldn't need to replace it, from a structural standpoint that is. If it were my car I'd take this opportunity to make a nice floor hugging driveshaft loop to replace it with.
'67 Notchback- 12.85 @ 109mph
« Reply #2 on: April 20, 2008, 01:59:12 PM »
But the torsion bar crossmember also is a transmission mount isn't it?
-46 Fargo
« Reply #3 on: April 20, 2008, 06:22:50 PM »
yes it is the tranny mount as well ... the prebent 3X2 cross member is a good idea but i think it may still be to big to fit the tranny ... they also make a round one out of 1 5/8 tubing that might give you more clearance.
« Reply #4 on: April 20, 2008, 08:12:04 PM »
Would that be enough support tho for my floors and my trans?
-46 Fargo
« Reply #5 on: April 20, 2008, 08:22:54 PM »
i would just make my own 2 x 3 crossmember and tie it in with frame connecters at the same time Smiley
« Reply #6 on: April 20, 2008, 08:25:33 PM »
sure,   it is desigend to hold the rear end in place with 4 link or ladder bars ... some floors and the weight of the back of the tranny should be no problem ...
« Reply #7 on: April 20, 2008, 09:17:10 PM »
hmm I wonder if I could do 2x3" square tube up to the trans tunnel and bend some tube to go u around the tunnel for clearence for the trans.
-46 Fargo
« Reply #8 on: April 20, 2008, 11:14:46 PM »
Perfect time for a 518.
« Reply #9 on: April 21, 2008, 01:55:11 AM »
-46 Fargo
« Reply #10 on: April 21, 2008, 01:23:40 PM »
An automatic overdrive trans.
Saint Paul, MN
« Reply #11 on: April 21, 2008, 01:56:03 PM »
 brain fart  What the hell was I thinking?!
« Reply #12 on: April 21, 2008, 07:33:45 PM »
lol right forget that I have one in my 98. No way am I spending 2500 ever again to rebuild an electronically controlled 727.
-46 Fargo
55robert@bellsouth.net
« Reply #13 on: April 22, 2008, 10:25:16 AM »
just cut out the rusted crap and torsion bar thingy and weld the correct thickness sheet metal back in and use the stock trans mount. cost a few bucks.
