Topic: Correct black? (Read 168 times)
MVRCorp
Boy, since I started this project I've learned alot about rattle can painting. I never knew there were that many colors of black. So what do you think is correct for this item? Flat, Matt or trim black?
what the hay is it?
MVRCorp
Something you don't have a use for....  . It's the rear dash cover....you know....the thing over to 2 6x9 speakers.
oh, ok
I would bet it should be satin black. A flat would probably soak into the package tray material and look odd, where the satin would still soak in, but not look as odd as a flat would. It would have a little sheen to it but not much. Definately not shiney or glossy looking as that may cast shadows on the rear glass.
