August 30, 2008, 09:55:08 AM
| | |-+  question for alterktion owners
Author Topic: question for alterktion owners  (Read 297 times)
TUBBED68CUDA
« on: April 22, 2008, 08:44:56 PM »
              Does anyone know if the AlterKtion(which has already been installed) can be taken out with it fully assembled? I figured I would ask before I beat my head against the wall.
      thanks,
    Erik     duster
Re: question for alterktion owners
« Reply #1 on: April 22, 2008, 09:01:12 PM »
I don't see any reason it couldn't. Call Bill.
« Reply #2 on: April 23, 2008, 12:46:39 AM »
Upper control arms bolt into factory location........unbolt those, unbolt K-frame bolts......baddabing Blah Blah Blah
[img]
« Reply #3 on: April 23, 2008, 08:18:47 AM »
don't see why not..  unbolt the upper arms and the steering shaft and it should drop right out.
Administrator
White Haven, PA
« Reply #4 on: April 23, 2008, 09:55:01 AM »
I do that alot. However, by yourself it's clumsy because the weight is across the wheels, not at the crossbar where the jack fits. If you put a board or metal across under the lower control arm mounts and stick the jack under that, it's fairly balanced and you can remove it alone.
I made a little bracket for my jack to do it - 1x1 square about 30" long with a 6" leg on each side. Weld a little pin in the middle to fit in the jack, and on each end leg I put small piece of tubing split to make little round saddles that rest on the control arm mounts - but it was worth doing because I remove them so often.
TUBBED68CUDA
« Reply #5 on: April 23, 2008, 08:54:59 PM »
Thanks guys....surely appreciated. Looks like I'll be building me one of them there fancy jack attachments... It will save a lot of  .
Erik   duster
