I probably have that much $$ in mine but I feel that I have a lot better system, although I think it will stop quicker than theirs I can't prove it. Yet!
This is what I did:
71 Scamp
w/73 Dart K-Frame, UCA/LCA, Spindles
Schumacher mounts and a 383/727
Front = 11.75” Cordoba Rotors with Porsche Boxster 'S' 4 piston Calipers (Brembo). (CNC adapter I designed)
13+ front Rotors coming and maybe brackets for sale if there is enough interest
B-Body rear narrowed w/Moser axles and MP spring relocation kit (not in Frame only .8”)
Mustang Cobra 11.69” rotors and calipers on the rear. (CNC adapter/brackets I designed)
E-brake cables from Cobra work but drivers side had to be shortened.
Wheels & Tires:
17” x 8” x 12mm KMC Hot Wheels 68 with 255/40x17 Pirelli P Zero on the front
17” x 9” x 24mm KMC Hot Wheels 68 with 275/40x17 Pirelli P Zero on the rear
There is NO room for any more tire but then that’s the idea. Isn’t it? :>)
YES, I've driven it and nothiing rubs!
I haven't yet tested/measured stopping distances but I expect <110' from 60. We'll see.
Note: There are no spacers on either front or rear and I had custom centering rings CNC machined so that they are hub-centric.
These wheels are only available at Discount Tire
http://www.discounttire.com These are the same wheels Rick Ehrenberg used on the Bold Beeper. I’m think he used 0mm offset all around. Note: The 17x8x12mm offset do not show up on the website but they are available! Make the counter guys check stock. Lucky for me my son works at Discount and he searched and found them. These are great looking wheels for the price.
I have pics but I cannot post them until I have 10 posts (this is #10!).
You can see the rear here:
http://www.bigblockdart.com/index.php/topic,10486.0.html Here is a question for you pros (in the business). What's an 8-3/4 built like this worth??
PM me for pics if you like.
Scamp
