October 11, 2008, 11:05:50 AM
| | |-+  Driveline offset
Author Topic: Driveline offset  (Read 312 times)
68snewpy
Driveline offset
« on: April 24, 2008, 05:39:27 PM »
I'm scrapping the 7 1/4 rear in my Duster in favour of a Ferd 8.8 from and explorer.  Now, before you get all pissey on me I can't find anything mopar around here at a decent price and this rear has 3.73 gears and limited slip already.  The pinion is offset about 2.5" to the right.  I may have to narrow the long side and install another short side axle (this results in stock a-body width).  I am hoping to install as is and was wondering what the problems might be.  I can live with the extra width and I know that the drive line is offset to the right in a-bodies anyway but not sure how much.  Any predictions of insight would be appreciated.
mopowers
Re: Driveline offset
« Reply #1 on: April 24, 2008, 07:01:30 PM »
I cut my Dana 60 down to have a 1 5/16" pinion offset.  I bet anywhere from 1 1/4" to 1 1/2" will be fine.
2006 Dakota
74duster383
« Reply #2 on: April 25, 2008, 09:03:30 AM »
When I installed my engine and tranny last year using a motor plate I had to research this as well so I knew how far to off set it.  If I remember correctly the engine is offset to the right (passenger side) 2 1/2 inches.
73 Charger
74 Duster Drag car
MVRCorp
« Reply #3 on: April 25, 2008, 09:38:39 AM »
Having an offset is important to the life of the u-joints. If it was a perfect straight line thru the driveline from the harmonic balancer to the rear end all the stress would be on a few needle bearings as there would be no movement at the u-joints.
Nitrous340dart
« Reply #4 on: April 26, 2008, 11:23:30 PM »
When I was narrowing my D60 i talked with Chris Alston chassie works and Strange, they said that having the pinion centered in the rear end would be ok as long as I had pinion angle off set a few degrees.  I dont plan on putting a lot of miles on the car.  But if I was build a street car I would probably had the pinion off set a little.
If it has tits or wheels it will give you problems!! nitrous4 speed   drinks
illfish
« Reply #5 on: April 27, 2008, 11:00:01 AM »
I think the Ford 8.8 is a great way to go.  Real tough rear end.
abqdart
72 Swinger 394/727/8.75
« Reply #6 on: April 28, 2008, 01:23:08 AM »
 agree I almost did the same swap! Cant really go wrong. When you get it in take a shit load of pics and post.....let us know how it goes.
Rio Rancho N.M 87144
