Topic: Stance of 67 Dart with 3 inch lowing blocks and SS springs (Read 484 times)
Looks good! I need to do mine, too. Do you still need longer shocks with the blocks?
'67 Notchback- 12.85 @ 109mph
Womanator
Yes you still need longer shocks
Nitrous340dart
what are you doing for traction? Won't the lowering blocks increase axle wrap?
Womanator
Last year with 9 inch tire's and minimal traction the 60 ft time was 1.6's pedeling it out of the hole.Maybe axel wrap was the problem with the traction but I just put 13 inch wide tire's on.When I go to the track I'll post my 60 ft time's .
kowski71400
looks good. lets see pix with the front end complete. i like the cowl hood.
SS springs + 2" ride height, add 3" lower block = 1" lower than stock. Works for me! Still might be a bit rough on the track with that much block. I lost 60ft (got slower) with mine in so I went back to a 1". Back to low 1.5's. Car looked evil though. That oil pan is a whopping three finger from the ground. Don't try this at home... unless you have a welder!
kowski71400
puregts, that thing looks great. really good stance.
