July 06, 2008, 09:14:08 AM
| | |-+  Gauge Question
Author Topic: Gauge Question  (Read 173 times)
74' DART
Work in Progress
demonbbmopar@yahoo.com
Gauge Question
« on: April 27, 2008, 08:04:38 PM »
My gas and temp gauges are not working. I grounded the temp sensor and the gauge moved fine. Tells me that the gauge is ok. I removed the cluster, inspected the pins, and they all looked fine. I scuffed up the copper circuit board and couldn't see any breaks in it. I replaced the instrument voltage regulator. reinstalled it made sure to have good connection from wiring harness. Still dont have either gaue. Tried to groung sending unit at the tank, but it made no difference. I grounded the back of the gauge and the gauge read full. Going to have to get my power probe from work to see if everything is getting power. Any suggestions?
Allentown, PA
Re: Gauge Question
« Reply #1 on: April 27, 2008, 08:42:19 PM »
sounds like you need a temperature sender for the temp guage, and the wire from the tank to the gas guage is broken.
nothingbutdarts
Re: Gauge Question
« Reply #2 on: April 27, 2008, 10:20:44 PM »
                       agree
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
   Bailey, Colorado
Re: Gauge Question
« Reply #3 on: April 27, 2008, 11:38:13 PM »
Get a spool of wire and temporarily run it from the gas tank sender to the gauge. Shorted it should read all one way and open the other then try it from the tank. Sometimes the wire inside the plug on connector for the tank disconnects or breaks off inside where you can't see it. The same thing happens with the temp sender too.
74' DART
Work in Progress
Re: Gauge Question
« Reply #4 on: April 29, 2008, 07:02:42 PM »
I checked the copper circuit board on the back of the cluster and it is grounded. The back of the temp gauges and the circuits running from the instrument voltage regulator to the gauges are grounded is this normal?
