July 06, 2008, 08:43:17 PM
| | |-+  REPLACING DASH PAD QUESTION.
Author Topic: REPLACING DASH PAD QUESTION.  (Read 346 times)
ALLMOPARCARS
Cleveland,Ohio
« on: April 28, 2008, 12:35:44 AM »
wHEN REPLACING THE DASH PAD, OR REMOVING, DOES THE WINDSHIELD NEED TO BE REMOVED THANKS miKE
OWNER/OPERATOR/FABRICATOR  (LEAGALLY),
ITS MY 13 YEAR OLDS FIRST CAR (69 DART GT) GOT TIRE?
SWEET! 4 speed
Cudadust
Re: REPLACING DASH PAD QUESTION.
« Reply #1 on: April 28, 2008, 02:28:01 AM »
On an A-body, four castle nuts are evenly spaced along the top and two screws on the outer curve about half way down. Remove these and the dash will slip off with a slight tug.
ALLMOPARCARS
Cleveland,Ohio
« Reply #2 on: April 28, 2008, 08:22:35 AM »
thanks i'll give it a goo around.
SWEET! 4 speed
CA Duster 383
« Reply #3 on: April 28, 2008, 11:17:08 PM »
It's only necessary to remove the windshield if you want to remove the metal dash, but not the dash pad.
Phil Saran
74 Duster 383
Fullerton, CA
« Reply #4 on: April 28, 2008, 11:57:20 PM »
There's five nuts across the back, AND you don't have to remove the windshield to remove the dash, either. It's just harder and requires cutting the fasteners.
Dantheman
« Reply #5 on: April 30, 2008, 11:04:12 PM »
Quote
The metal dash frame??  What fasteners do you cut? If so how can you reinstall the dash frame with the windshield installed-use very short screws? Have tried to remove the frame with the windshield and decided it was not possible.....
1980 Volare manual on the floor-radio delete. 1970 383 4 speed 'cuda. 1968 383 Charger. 71 429 CJ Torino J code. 70 429 SCJ 70 Torino 4 speed,drag pack. 70 351c  ragtop Mustang. 68 302 Torino GT-all original. 68 GTO 400 auto.
gearhead01
If you don't fail, you cannot succeed.
« Reply #6 on: June 09, 2008, 11:24:28 PM »
Hello All:
I assume the dash pad removal is for the top pad.  What do you have to do to remove the lower "dash pad" on a 68 Valiant?
1968 Plymouth Valiant 2-Door Post Bracket Car In Progress
1971 Plymouth Satellite Sebring Plus, 383, Auto 14.50 @ 95 MPH
MoPar_or _NoCar
MoParaised
« Reply #7 on: June 10, 2008, 12:19:04 AM »
Hello All:
Remove the retaining nuts. 3 left, 4 right Ithink.
63' Dart GT 225/904/7.25 but totaly original =Black w/Red int.
68' Dart   Soon to be 383!
70' Challenger 440 / 727 / 8.75w3.23 suregrip 80% complete
93' Shadow ES  Daily Driver
97' 1500 318 4X4 Chipped and breathes good
08' Avenger R/T Family Sedan
gearhead01
« Reply #8 on: June 10, 2008, 10:49:54 PM »
Thank you for the information.  I have to go diving under the dash soon to remove the top/bottom dash pads and unsnarl all the wiring the last owner rigged up when they converted the car to a racer.
Thanks again.
