Topic: REPLACING DASH PAD QUESTION. (Read 387 times)
ALLMOPARCARS
Cleveland,Ohio
wHEN REPLACING THE DASH PAD, OR REMOVING, DOES THE WINDSHIELD NEED TO BE REMOVED THANKS miKE
OWNER/OPERATOR/FABRICATOR (LEAGALLY), ITS MY 13 YEAR OLDS FIRST CAR (69 DART GT) GOT TIRE? SWEET!
Cudadust
On an A-body, four castle nuts are evenly spaced along the top and two screws on the outer curve about half way down. Remove these and the dash will slip off with a slight tug.
ALLMOPARCARS
Cleveland,Ohio
thanks i'll give it a goo around.
CA Duster 383
It's only necessary to remove the windshield if you want to remove the metal dash, but not the dash pad.
Phil Saran 74 Duster 383 Fullerton, CA
There's five nuts across the back, AND you don't have to remove the windshield to remove the dash, either. It's just harder and requires cutting the fasteners.
Dantheman
There's five nuts across the back, AND you don't have to remove the windshield to remove the dash, either. It's just harder and requires cutting the fasteners. The metal dash frame?? What fasteners do you cut? If so how can you reinstall the dash frame with the windshield installed-use very short screws? Have tried to remove the frame with the windshield and decided it was not possible.....
1980 Volare manual on the floor-radio delete. 1970 383 4 speed 'cuda. 1968 383 Charger. 71 429 CJ Torino J code. 70 429 SCJ 70 Torino 4 speed,drag pack. 70 351c ragtop Mustang. 68 302 Torino GT-all original. 68 GTO 400 auto.
gearhead01
If you don't fail, you cannot succeed.
Hello All:
I assume the dash pad removal is for the top pad. What do you have to do to remove the lower "dash pad" on a 68 Valiant?
1968 Plymouth Valiant 2-Door Post Bracket Car In Progress 1971 Plymouth Satellite Sebring Plus, 383, Auto 14.50 @ 95 MPH
MoPar_or _NoCar
MoParaised
Hello All:
Remove the retaining nuts. 3 left, 4 right Ithink.
63' Dart GT 225/904/7.25 but totaly original =Black w/Red int. 68' Dart 383 / 727 / 8.75w3.55 suregrip 70' Challenger 440 / 727 / 8.75w3.23 suregrip 80% complete 93' Shadow ES Daily Driver 97' 1500 318 4X4 Chipped and breathes good 08' Avenger R/T Family Sedan
gearhead01
Thank you for the information. I have to go diving under the dash soon to remove the top/bottom dash pads and unsnarl all the wiring the last owner rigged up when they converted the car to a racer.
Thanks again.
