Topic: trunk rust help (Read 215 times)
wjaholic
“Give me a place to stand and a lever long enough and I will move the world.” - Archimedes
mshred
Well there are two little holes just a bit bigger than a pinhole that you can see daylight through....im guessing if thats the case i should probably go with replacing the panel? I know its hard to tell from the pictures i posted, but even with those holes, the whole panel is pretty solid...replacement panels arent cheap either, so i just want to be sure that i can stop the rust another way besides from buying a patch panel for it...what do you guys think?
mshred
Anybody got any advice on this...i know its probably been asked before, but im not so sure as what to do...please look at my pics (sorry i couldnt upload them) and let me know what you guys think i should do...
rjsjea
Depends on what you want the final product to look like....show car, driver etc...
I would sandblast the area to remove the rust and paint. Then you will know what you have.....it will probably have more than two small holes that you can see now.
Cut out the bad metal and replace with a new panel or make one to fix it. After you sandblast, patch, then Epoxy prime.
kendog170
Looks like your outer extension panel could be replaced,then maybe patch the trunk.I've had good luck with Autobody Specialties in Conn. .They have a website.I,ve bought rear quarters ,trunk floor complete center $188., front floorpans(Fit Nice) for my 68 Dart,but I'm in New England area and picked up myself.I'm sure shipping on just the extension won't be bad.
 68GTS Ragtop 340 4spd.200K miles and current 500 Stroker project.  It all Started With a Hood
