October 07, 2008, 07:16:45 PM
| | |-+  trunk rust help
Author Topic: trunk rust help  (Read 256 times)
mshred
trunk rust help
« on: April 28, 2008, 07:19:11 PM »
Hey guys just wanted to know what you think i should do to fix this rust in the trunk of my 71 scamp....i have some pictures attached here on...the area is on the right side of the trunk behind the wheelwell...here are the pictures..should i replace the whole panel, or should I use another method to stop it (i.e. naval jelly or eastwood stuff)...let me know what you guys think thank you
http://s296.photobucket.com/albums/mm183/mshred/71%20Scamp/?action=view&current=DSC04303.jpg
http://s296.photobucket.com/albums/mm183/mshred/71%20Scamp/?action=view&current=DSC04304.jpg
http://s296.photobucket.com/albums/mm183/mshred/71%20Scamp/?action=view&current=DSC04305.jpg
wjaholic
Re: trunk rust help
« Reply #1 on: April 28, 2008, 08:50:21 PM »
Well, I would take a wire wheel or a wire brush and start cleaning on it. If you find any holes they will need to be fixed (like mine below). If you don't find any holes or extensive rust damage (consider yourself lucky!), I would coat it with a good coat of POR-15.  http://www.por15.com/
My car is in sad shape, I know I know. My patch work looks like crap but, I am doing my best and working on it outside in 45 degree weather isn't easy.
I have used POR-15 on a lot of stuff, I recomend it every chance I get.
mshred
Re: trunk rust help
« Reply #2 on: April 29, 2008, 09:00:02 AM »
Well there are two little holes just a bit bigger than a pinhole that you can see daylight through....im guessing if thats the case i should probably go with replacing the panel? I know its hard to tell from the pictures i posted, but even with those holes, the whole panel is pretty solid...replacement panels arent cheap either, so i just want to be sure that i can stop the rust another way besides from buying a patch panel for it...what do you guys think?
mshred
Re: trunk rust help
« Reply #3 on: April 29, 2008, 11:09:04 PM »
Anybody got any advice on this...i know its probably been asked before, but im not so sure as what to do...please look at my pics (sorry i couldnt upload them) and let me know what you guys think i should do... thank you
Re: trunk rust help
« Reply #4 on: April 29, 2008, 11:51:48 PM »
Depends on what you want the final product to look like....show car, driver etc...
I would sandblast the area to remove the rust and paint.  Then you will know what you have.....it will probably have more than two small holes that you can see now.
Cut out the bad metal and replace with a new panel or make one to fix it.  After you sandblast, patch, then Epoxy prime.
mshred
Re: trunk rust help
« Reply #5 on: April 30, 2008, 08:53:54 AM »
I was looking on the cross canada parts site and found this link....
http://www.crosscanadaparts.com/cgi-bin/crosscanada/product_list.html?img_num=195
only thing is, im not sure if i need the RH trunk filler panel or the RH trunk floor extension panel Dunno
kendog170
Re: trunk rust help
« Reply #6 on: April 30, 2008, 01:04:22 PM »
Looks like your outer extension panel could be replaced,then maybe patch the trunk.I've had good luck with Autobody Specialties in Conn. .They have a website.I,ve bought rear quarters ,trunk floor complete center $188., front floorpans(Fit Nice) for my 68 Dart,but I'm in New England area and picked up myself.I'm sure shipping on just the extension won't be bad.
 68GTS Ragtop 340 4spd.200K miles and current 500 Stroker project. It all Started With a Hood
