Topic: moroso switch panel (Read 267 times)
grudd440
now its the time in my project for wiring. yay! Im not using any of the stock harness because im just going to run an alternator, battery, fan , ignition, guages, and starter switch. Im thinking of getting a moroso switch panel and my ? is: does it only require i hot wire to the panel for all circuits to work?
kiner
It's junk.All it is.Is switches,fuse holders lights and a panel.same as you can buy for 20 bucks.Do your homework on circuits.You will need some relays for your accessories. Good luck.
 Go look at your modern rides and you'll find a bunch of stuff is being handled by relays. Relays are your frien, they protect light duty switches from the high amp draws that would normally kill them. It's a shame GM hasn't learned this on their starters' circuit.
abqdart
cant you wire in a relay and a CB into the switch panel??
Rio Rancho N.M 87144
abqdart
just run the relay AFTER the toggle in line with a fuse or CB and then the trigger wire to the device? Its the device that draws the amps, so if the relay is between the toggle and the device the relay is supporting the amp draw and not the toggle.......someone wanna sanity check this
YUP you got it correct ....
abqdart
I picked up a switch panel from Quickcar.net and thats how Im going to wire up my Starter, Fuel Pump, Electric Fan and  . I picked up a few relays and a few CB's and fabbed up a small panel. I am using my EZ Wire Harness for everything else. Its actually quit simple once you sit down and think about how your going to do it. I will snap some picks of the lay out if ya'll want? Let me know
grudd440
im wiring it up right now. it just takes time.
