Topic: Dash removal (Read 397 times)
sperrydan
Im trying to get the whole dash out . How does it come out. I see the 2 bolts on the bottom next to the doors on both sides. Do you have to remove the winshild to get the complete dash out
Dantheman
Yes,The windshield has to come out. There are five or six screws the have to come out.
1980 Volare manual on the floor-radio delete. 1970 383 4 speed 'cuda. 1968 383 Charger. 71 429 CJ Torino J code. 70 429 SCJ 70 Torino 4 speed,drag pack. 70 351c ragtop Mustang. 68 302 Torino GT-all original. 68 GTO 400 auto.
You can get it out w/o removing the windshield by cutting off the fasteners from underneath. It is much easier by removing the glass.
Re-installing with the glass in, I have never done this.......Another post says it can be done
sperrydan
Removing the glass scares me. I would hate to crack it. I have been putting of removing the glass bc of this but it looks like it must bedone.
Dart Guy UK
I have just taken the glass out of mine. The screen had delaminated across the whole bottom edge and although I was not too bothered if the screen broke or not as It was going to be repalced (hopefully), I found that by spaying into the screen seal with WD40 or simular for a couple of days before allowing it to fully penatrate as it softens up tyhe rubber very slightley and makes the screen removal very easy
Under constuction 1968 Dart Pro street 2dr sedan 440 11.5-, iron koffel max ported heads, crower hyd 530 cam, fenderwells, JW 4200 converter,4 link 8 3/4 4.56 gear with spool & 31x 18.5-15 out back It will be street leagal and gas is over $10 a gallon
Cut the fasteners, reinstall the fastners upsidedown with shorter screws.
smallbigblock
I should have left it alone
dart kid
If you do remove the windshield, a new one will cost around $230 w/ instal but before tax. I looked up Dart windshields a few weeks back while work was slow. (I work at NOVUS).
hemi62valiant
I am having problems removing mine as well. How does the push button mechanism's come off?
Eddie Walker
sperrydan
if i do take the glass out should i build a bax to hold them
Think about it for a moment; your trying to save a 30+ year old rubber gasket that probably leaks anyway. Especially if you have a vinyl top! Get out the box cutter and get a new rubber gasket. Yes, the glass price is at least $200. I'm having mine replaced, as we speak, even though I was able to remove the original one safely. Since I cut it out, I had to replace the old rubber gasket, but looking at this economically, a $65 gasket or a $200+ piece of glass?? Hmmm. Call me cheap, but if that new gasket works, my new carpet will be a whole lot drier came the rains.
sperrydan
I was planing on just cutting them out and using new gaskets and trim clips.
When I put new clips in, does the screws have a rubber washer or do i have to use a sealer to keep the holes from leaking?
