Topic: Welding Stainless/Aluminized Exhaust (Read 429 times)
jacks62440
Is there any problem mig welding stainless exhaust pipe to aluminized steel exhaust pipe
Jack
zpsull01
I've done it a few times without really thinking about it. This is a good question though....
jacks62440
It sounds like it worked though
Jack
sunsetdart
be careful of the fumes...they are toxic........also, to get penetration, you should grind off the aluminum where you are going to weld so the bond can be steel to steel.
The preferred method is 309L filler. This is available in Tig or Mig. If you use steel filler (ER70), cracking could occur.
jamesdart
i have to say, ive blasted a few sets of stainless tips on with regular steel mig wire, 75/25 and didnt even touch the coating. never had a problem. for an exhaust system i dont think you would have a problem.
pirate
Welding the aluminized will work just fine. Be carefull welding the stainless though. The fumes are way more toxic than most people understand. Make sure you have plenty of ventilation, or ideally, wear a respirator while you weld it. At work we have to wear a self contained breathing pack to weld stainless. good luck!
Jon
Give a man a match, he'll be warm for a minute. Set a man on fire, he'll be warm for the rest of his life!
375InStroke
What are the fumes. You would need the correct type of filter to be effective. How do you fit a respirator under an arc hood?
MoPar_or _NoCar
63' Dart GT 225/904/7.25 but totaly original =Black w/Red int. 68' Dart Soon to be 383! 70' Challenger 440 / 727 / 8.75w3.23 suregrip 80% complete 93' Shadow ES Daily Driver 97' 1500 318 4X4 Chipped and breathes good 08' Avenger R/T Family Sedan
kudah440
uh-oh... my fish are gonna be in trouble when the tank stand welds crack  The preferred method is 309L filler. This is available in Tig or Mig. If you use steel filler (ER70), cracking could occur.
Jeremy 69 BCuda 383 71 Duster 440 74 Scamp 340 All in differing states relative to my state of mind
