October 12, 2008, 11:37:51 PM
| |-+  Early A-bodies
| | |-+  Seam sealer remover?
Author Topic: Seam sealer remover?  (Read 532 times)
hemi62valiant
« on: May 03, 2008, 08:15:57 AM »
What are you using to remove tar and seam sealer from inside car?
Eddie Walker
sunsetdart
us4ever365@hotmail.com
Re: Seam sealer remover?
« Reply #1 on: May 03, 2008, 08:48:53 AM »
If the seam sealer is in between seams, you may just get out what you can see. Or you can soak it with something like lacquer thinner to soften it up and try getting it out. The same thing goes for the tar. You may also want to try acetone rather than thinner to, but be careful of the fumes in either case, especially in an enclosed area like the interior.
hemi62valiant
« Reply #2 on: May 03, 2008, 08:56:18 AM »
thank you. I didnt even think about lacquer thinner
Eddie Walker
Ivor383
« Reply #3 on: May 03, 2008, 09:01:20 AM »
I got the sealer out with both a twisted bristle wire brush on an angle grinder and warmed up the bitumastic stuff with a heat gun (careful, not too hot!) and a putty knife, came off a treat!
Apparently, I have a 1964 Plymouth Barracuda!
scott
« Reply #4 on: May 04, 2008, 01:29:42 AM »
Try a Pneumatic needeler, They work great for all that & undercoating .
After that a swipe with a rag & thinner.
x360x64dart
« Reply #5 on: June 06, 2008, 08:05:21 PM »
 agree works good just make sure you wear a mask for sure.
It's almost a big block! Escondido,CA
