August 20, 2008, 05:53:25 PM
| | |-+  Is this an A body BB K frame?
Author Topic: Is this an A body BB K frame?  (Read 664 times)
bigblock1974
« on: May 04, 2008, 10:25:22 PM »
Hi I purchased this for my Dodge Dart Sport BB build. It costed me $100.00 It's going to be sent out to Firm Feel Suspensions to get blast tanked and welded for extra strength. Can someone tell me if this is the right k frame? I just hope I didn't get ripped off.
Thanks,
Administrator
White Haven, PA
Re: Is this an A body BB K frame?
« Reply #1 on: May 04, 2008, 11:08:01 PM »
Nope. It's a standard issue 73-up a-body frame. Although it appears to have the 72-down idler on it.
You CAN still use it though, it you do some modifying, as shown on this page.... http://www.bigblockdart.com/techpages/dck.shtml
Administrator
White Haven, PA
« Reply #2 on: May 04, 2008, 11:11:14 PM »
Oh...I should also add - you'll be better off this way than if it really was an original BB kframe - the originals also required a special driver-side motor mount, which is still available, however it only fits on certain engine blocks, so to use an original BB K, you have to use special mounts, AND a specific engine block.
By modifying the one in the pictures, you'll be able to use any standard B block, which is a far better situation when you start building an engine.
A13Dart
Minnesota
« Reply #3 on: May 04, 2008, 11:20:13 PM »
It looks like someone has already moved the mounts back to the big block position.
Administrator
White Haven, PA
« Reply #4 on: May 04, 2008, 11:29:19 PM »
Good point, not that I stare a bit closer Grin   Drive side seems obvious... can't tell if the passenger side was moved or not.
Administrator
White Haven, PA
« Reply #5 on: May 04, 2008, 11:30:56 PM »
Ahh yep, you can see the passenger one too. Ok, I retract some info - it IS a 73-up V8 frame, but it's already modified Grin
« Reply #6 on: May 05, 2008, 12:11:16 AM »
Yes, it's a modified 73-76 k-member. Might be to DC specs, might not. You'd have to measure it. I can't tell from the pics if it's a DC k-member or home-built. A picture of the driver side saddle from the passenger side would tell.
blasphemous
« Reply #7 on: May 07, 2008, 04:53:06 AM »
In the write-up, is it supposed to be 1 and 3/16" or 13/16"?
« Reply #8 on: May 07, 2008, 11:07:05 AM »
Both. Driver side 1-3/16" and passenger side 13/16".
gearhead01
If you don't fail, you cannot succeed.
« Reply #9 on: May 27, 2008, 10:03:38 PM »
I am new to BigBlockDart, and I must say all of this information is great.  I picked up a '68 Valiant in April and am still sorting out what I have.  The pictures in this post and the information in the referenced Tech Section match up with the set-up in my car.
So, here are my questions:
1.  With the '73 to '76 modified "K" frame, what oil pans can be used with out interference with the "K" frame and tie rod?  I am in the process of cleaning/painting the engine compartment.  If I need to modify anything on the "K" frame, now is a perfect time.
2.  What headers work the best with this "K" frame?  The car is cut for fenderwell headers, but I prefer to go with under chassis.
Any of your experiance will be appreciated.
Thanks,  John
1968 Plymouth Valiant 2-Door Post Bracket Car In Progress
1971 Plymouth Satellite Sebring Plus, 383, Auto 14.50 @ 95 MPH
« Reply #10 on: May 28, 2008, 01:21:33 AM »
The DC k-member puts the engine in the stock location, BUT each car is a little different. Generally speaking the C-body oil pan will fit without mods, but the dimple may have to be enlarged. Having never run headers I can't tell you what fits best, but go through the tech pages for the options.
BigSlim
« Reply #11 on: May 31, 2008, 09:49:31 AM »
How do I tell the difference between a 73 and up  versus a 72 and down K frame?
1967 Barracuda 440  fast back
1969 Barracuda 340  Fast back
golferjohn
« Reply #12 on: May 31, 2008, 06:49:11 PM »
Dang...these guys are GOOD!!
« Reply #13 on: May 31, 2008, 07:17:23 PM »
BigSlim
« Reply #14 on: June 02, 2008, 07:08:08 AM »
Joe,
thank you
