October 13, 2008, 06:14:23 AM
| | |-+  11/16 Tie Rod Upgrade Question
Author Topic: 11/16 Tie Rod Upgrade Question  (Read 221 times)
67Satty
« on: May 05, 2008, 01:05:59 AM »
Just Suspension has a kit with inner and outer tie rods and adjusting sleeves for $189.95 but Rockauto.com has Moog Parts for a C-Body, part numbers es352R  outer   es355RL  inner    es440S   sleeves, for about $110.00 altogether.
Isn't the 11/16 tie rod upgrade just C-Body stuff?
Will the 11/16 stuff listed for a '67 C-Body Fury work on my '67 B-Body Satellite?   thank you
In the garage:  '67 Plymouth Satellite - once my 318-powered daily driver, now my project car with lots of "patina"
On the stand:  "Old School" '71 440 build:  "6 Pack" pistons at zero deck, Engle .534, 238@.050" Hyd, stock 452s, Performer RPM, 850 DP, Hooker headers.  Still need: ignition, gears
Wisconsin
Re: 11/16 Tie Rod Upgrade Question
« Reply #1 on: May 06, 2008, 01:46:41 AM »
www.firmfeel.com has a kit cheaper than Just Suspension. Neither of these sites specifies Moog tie rod ends, though.
The tie rod ends are C body items.
According to the Just Suspension site, A,B, and E bodies are supposed to use the same sleeve as C bodies. I don't know for sure if that's really the case.
The sleeve you get from Rock Auto will be a split factory-style piece. The solid sleeve is stronger, which is what you're going for, I assume. Maybe get the good Moog ends from Rock Auto, and the sleeves from Just Suspension or Mancini Huh
Mark
Sacramento CA.
« Reply #2 on: May 06, 2008, 03:58:39 AM »
I got some 11/16" C body ends from Autozone and got a set of stock C body sleeves from the local junk yard. The sleeves were too long for an A body, they didn't leave any adjustment. So I ended up getting a set with the jam nuts form a seller on Ebay at the right size I needed ( 7"). All together I have about $80 into the whole set-up.
« Reply #3 on: May 06, 2008, 11:11:42 AM »
Firm Feel sells them for B bodies. I guess they alter the length. I have them, but I haven't compared them to stock parts yet.
