July 24, 2008, 12:15:02 AM
|-+  General Category
| |-+  Wanted
| | |-+  parts needed for 4 speed swap
Author Topic: parts needed for 4 speed swap  (Read 399 times)
Jamakin
makin678@hotmail.com Jamakin99
« on: May 05, 2008, 08:23:34 PM »
I figured while i was looking for things i would also post asking for some of the other 4 speed parts i need to see if anybody had anything to help out.
I am looking for the following....all of which will be going in my 74 duster
10.5 bigblock bellhousing
clutch/brake pedal
4 speed floor hump
bigblock clutch fork (planning to buy from brewers if i can't find used)
bigblock z-bar (also planning to buy from brewers if i can't find used)
let me know if anybody can help out, i'm not in a huge rush just trying to get the parts ready  !nanr
dart540
Re: parts needed for 4 speed swap
« Reply #1 on: May 06, 2008, 01:53:48 AM »
Have the clutch and brake pedal assembly if you still need pm me here Thanks Stan.
Josh
« Reply #2 on: May 06, 2008, 09:05:26 PM »
I have an aluminum bell on a 383. Not sure if ti is what you are looking for or not.
I need a 727 for a big block maybe we can work something out.
Jamakin
« Reply #3 on: May 07, 2008, 06:40:35 PM »
Josh
where are you located, i have a bigblock 727 that i'm not sure of it works or not.  I was told it was taken out of a running car but i haven't used it or opened it up.  In either case it would def be a good core for a rebuild.  I'll have to measure my 4sp to see what size the bearring retainer is and you can let me know if the bellhousing you have is the same.  I am looking for the 10.5 bellhousing for sure but not sure wthe retainer size, i know my 4spd came from a 69 barracuda
Stan
any word on pictures of the pedal setup?
Josh
« Reply #4 on: May 07, 2008, 08:03:23 PM »
Josh
mapquest 16255
Quote
I have to put in a short tailshaft for a 4wd anyway so i dont mind  a rebuild.
Quote
I have no idea what the bell is from. This weekend ill try to pull it off and measure the retainer hole and the flywheel diameter.
Jamakin
« Reply #5 on: May 07, 2008, 08:21:57 PM »
Josh
mapquest 16255
Quote
Quote
thanks josh, your only about 80 miles from me so if all works out this could be a pretty easy deal
Jamakin
« Reply #6 on: May 10, 2008, 03:37:15 PM »
bump .... anybody have any parts to make a deal with?
Josh
« Reply #7 on: May 10, 2008, 03:53:07 PM »
Ill get some numbers tonight. I had to work this morning.
Jamakin
« Reply #8 on: May 10, 2008, 04:18:34 PM »
ok thanks josh
Jamakin
« Reply #9 on: May 12, 2008, 10:32:23 PM »
I found pedals, but i still need the other parts
10.5 bigblock bellhousing  (still need)
clutch/brake pedal (found!)
4 speed floor hump (still need)
Josh
« Reply #10 on: May 13, 2008, 10:47:04 PM »
Sorry I have not got back to you. I have been dealing with a sick 2 year old. I will make time this week to get some info for you.
Jamakin
« Reply #11 on: May 15, 2008, 08:07:30 AM »
no problem man thanks for keeping me posted
Four40Dart
GET REAL GET MOPAR!!
« Reply #12 on: May 15, 2008, 07:20:20 PM »
I have a four speed floor hump out of a 70 duster
Josh
« Reply #13 on: May 15, 2008, 08:52:53 PM »
I took 10 minutes before work to pull the bell off. I was wrong about it being aluminum. It appears to be cast.  i did not get the hole measured or the diameter of the flywheel. Ill clean it off and make some measurements tomorrow since the boy seems to be feeling better.
Jamakin
« Reply #14 on: May 16, 2008, 03:47:05 PM »
What shape is it in and do you have any pictures? also how much?
Thanks
Jim
