Topic: parts needed for 4 speed swap (Read 390 times)
Jamakin
I figured while i was looking for things i would also post asking for some of the other 4 speed parts i need to see if anybody had anything to help out. I am looking for the following....all of which will be going in my 74 duster 10.5 bigblock bellhousing clutch/brake pedal 4 speed floor hump bigblock clutch fork (planning to buy from brewers if i can't find used) bigblock z-bar (also planning to buy from brewers if i can't find used) let me know if anybody can help out, i'm not in a huge rush just trying to get the parts ready
dart540
Have the clutch and brake pedal assembly if you still need pm me here Thanks Stan.
Josh
I have an aluminum bell on a 383. Not sure if ti is what you are looking for or not.
I need a 727 for a big block maybe we can work something out.
Jamakin
Josh where are you located, i have a bigblock 727 that i'm not sure of it works or not. I was told it was taken out of a running car but i haven't used it or opened it up. In either case it would def be a good core for a rebuild. I'll have to measure my 4sp to see what size the bearring retainer is and you can let me know if the bellhousing you have is the same. I am looking for the 10.5 bellhousing for sure but not sure wthe retainer size, i know my 4spd came from a 69 barracuda Have the clutch and brake pedal assembly if you still need pm me here Thanks Stan.
Stan any word on pictures of the pedal setup?
Josh
Josh where are you located, mapquest 16255 i have a bigblock 727 that i'm not sure of it works or not. I was told it was taken out of a running car but i haven't used it or opened it up. In either case it would def be a good core for a rebuild. I have to put in a short tailshaft for a 4wd anyway so i dont mind a rebuild. I'll have to measure my 4sp to see what size the bearring retainer is and you can let me know if the bellhousing you have is the same. I am looking for the 10.5 bellhousing for sure but not sure wthe retainer size, i know my 4spd came from a 69 barracuda I have no idea what the bell is from. This weekend ill try to pull it off and measure the retainer hole and the flywheel diameter.
Jamakin
Josh where are you located, mapquest 16255 i have a bigblock 727 that i'm not sure of it works or not. I was told it was taken out of a running car but i haven't used it or opened it up. In either case it would def be a good core for a rebuild. I have to put in a short tailshaft for a 4wd anyway so i dont mind a rebuild. I'll have to measure my 4sp to see what size the bearring retainer is and you can let me know if the bellhousing you have is the same. I am looking for the 10.5 bellhousing for sure but not sure wthe retainer size, i know my 4spd came from a 69 barracuda I have no idea what the bell is from. This weekend ill try to pull it off and measure the retainer hole and the flywheel diameter. thanks josh, your only about 80 miles from me so if all works out this could be a pretty easy deal
Jamakin
bump .... anybody have any parts to make a deal with?
Josh
Ill get some numbers tonight. I had to work this morning.
Jamakin
ok thanks josh
Jamakin
I found pedals, but i still need the other parts I am looking for the following....all of which will be going in my 74 duster 10.5 bigblock bellhousing (still need) clutch/brake pedal (found!) 4 speed floor hump (still need) bigblock clutch fork (planning to buy from brewers if i can't find used) bigblock z-bar (also planning to buy from brewers if i can't find used) let me know if anybody can help out, i'm not in a huge rush just trying to get the parts ready
Josh
Sorry I have not got back to you. I have been dealing with a sick 2 year old. I will make time this week to get some info for you.
Jamakin
no problem man thanks for keeping me posted
Four40Dart
GET REAL GET MOPAR!!
I have a four speed floor hump out of a 70 duster
Josh
I took 10 minutes before work to pull the bell off. I was wrong about it being aluminum. It appears to be cast. i did not get the hole measured or the diameter of the flywheel. Ill clean it off and make some measurements tomorrow since the boy seems to be feeling better.
Jamakin
What shape is it in and do you have any pictures? also how much? Thanks Jim
