Topic: Cummins help (long shot) update photo (Read 349 times)
Summit925
ok this is a long shot but i have a 2000 cummins with the edge comp chip now coming out of the back of the chip there is a gray/white wire coming out and going into a block cylinder looking thing with 101K on the side my wire broke off this and now it doesnt run right, what is this! i know its a long shot but maybe someone might know im thinking capacitor please help!
Any chance you can split the above sentence up, so that some one else can read it and understand what you are asking ? Thanks !
BigSlim
1967 Barracuda 440 fast back 1969 Barracuda 340 Fast back
Great Wife, Kids and many, many blessings!!
Looks more like a resistor by the markings anyway. 101K is normally a marking for a 101,000 ohm resistor. Unfortunately it isn't marked for wattage. Going off it's size, this is a huge guess, it looks about a 5-10watt resistor. Most of the ones you see in radios and on circuit boards are 1/8 to 1/4 watt resistors as they are about the length of your index finger nail's width and about the diameter of a #8 screw. Generally speaking, the larger the size the higher the wattage. This is nothing Radio Shack stocks I'm sure. Putting the wrong wattage one in could cause damage to the ECU. Best to E-mail the MFG and get the right stuff. A capacitor uses a different measurement (UF) micro phareds and pico phareds (PF). Sorry, I'm sure I butchered the "phareds" spelling, but you get the point.
Summit925
haha yeah i went into radio shack and the guy behind the counters like nope never seen anything like it and never even took a second look, i emailed edge the other day with no luck so far  there also is a marking of VW-1 on the other side does that mean anything? also started pulling the rubber insulation off and it looks like a coil of wire inside thanks guys you are the best
Nitrous340dart
I'll sell you my TST PM3  Where did the other end of the wire go? As far as I know the only wires that are coming from the edge are going to the VPpump (tap wire) your map sensor and key-on hot and bat hot and ground. If you have a test light see if your getting ground and voltage. Have you tried looking at there install PDF? If they dont have then try looking at TSTproducts or Quadzilla. All the boxes for the 24v 2gen pretty much hook up the same.
Okie
you probably dont want to hear it but if i were you ide get rid of that edge and get the BD tripple dog, or a smarty
