Topic: Air bag suspension (Read 348 times)
MyCreation68
Looking to swap to a coil over front kit minus the coil overs. I'm going to do a independent rear suspension to so I want air bags back there to. Anyone know what kind of bags i should run and also how low I can get the frame?
I don't suffer from road rage, I enjoy every minute of it. My vehicles:  -1984 Dodge Ramcharger 318 auto 4x4 atc stock beast -1968 Dodge Dart GT 6cyl auto buckets console work in progress -1966 Bridgestone 90 Deluxe -1946 Fargo 3/4 ton
rjsjea
...AlterK and Street Lynx 4 link is available with air. That would probably be the easiest and best way to go, since the suspension geometry is figured out already and it's almost a bolt in
MyCreation68
$$$ can't afford it.
MyCreation68
Oh definitly the AlterK and the street lynx are awesome but I can't afford ether right now. I'm eventually going to buy the alterk but I like the idea of having independent rear suspension for handling.
blackbetty
Are you planning on running an independent suspension or a link style suspension? Independent is like what you would find in a Viper or corvette Alterk is link style. I would recommend shockwaves for either setup. Since your trying to do it on the cheap you could use firestone bags with a external shock. Checkout some lowered truck sites.
Make the asphalt bleed!
MyCreation68
As stated in my original post it's getting independent rear suspension.
Cpt Panzer
I have been doing a lot of measuring on the IRS on the new charger. it certainly is not a bolt in , but it looks like it would require very little fabrication to make it work. I do however question the strenth and durability of the dif and housing. also any thing you would get out of a salvage yard would probably be trashed and cost at least an arm.
MyCreation68
Curious, what IRS are you using?
I'm going to be using a setup out of a ford thunderbird.
