October 13, 2008, 06:06:28 AM
| | |-+  Air bag suspension
Author Topic: Air bag suspension  (Read 395 times)
Air bag suspension
« on: May 07, 2008, 08:12:49 PM »
Looking to swap to a coil over front kit minus the coil overs. I'm going to do a independent rear suspension to so I want air bags back there to. Anyone know what kind of bags i should run and also how low I can get the frame?
-46 Fargo
Re: Air bag suspension
« Reply #1 on: May 07, 2008, 08:16:33 PM »
...AlterK and Street Lynx 4 link is available with air.  That would probably be the easiest and best way to go, since the suspension geometry is figured out already and it's almost a bolt in
« Reply #2 on: May 07, 2008, 08:19:54 PM »
$$$ can't afford it.
-46 Fargo
JWSewell
« Reply #3 on: May 07, 2008, 10:21:24 PM »
Air Ride Tech.  "SHOCKWAVES"
 http://www.ridetech.com/catalog/Universal_Applications-57-1.html
 Looks like you will have to fab the rest unless you go with the AlterK & Street Lynx 4!
 AlterK & Street Lynx FTW!
« Reply #4 on: May 08, 2008, 12:17:59 AM »
Oh definitly the AlterK and the street lynx are awesome but I can't afford ether right now. I'm eventually going to buy the alterk but I like the idea of having independent rear suspension for handling.
-46 Fargo
blackbetty
RoadKiller
« Reply #5 on: May 08, 2008, 05:45:16 PM »
Are you planning on running an independent suspension or a link style suspension? Independent is like what you would find in a Viper or corvette Alterk is link style. I would recommend shockwaves for either setup. Since your trying to do it on the cheap you could use firestone bags with a external shock. Checkout some lowered truck sites.
71 Dart,BB,t56,tube chassis,6in engine setback,Modified C4 corvette front suspension,custom 3link rear. Shooting for 200mph at the Maxton mile.
Make the asphalt bleed!
« Reply #6 on: May 09, 2008, 09:04:54 AM »
As stated in my original post it's getting independent rear suspension.
-46 Fargo
« Reply #7 on: May 12, 2008, 10:08:58 PM »
Curious, what IRS are you using?
Cpt Panzer
« Reply #8 on: May 12, 2008, 10:40:57 PM »
I have been doing a lot of measuring on the IRS on the new charger. it certainly is not a bolt in , but it looks like it would require very little fabrication to make it work.  I do however question the strenth and durability of the dif and housing.  also any thing you would get out of a salvage yard would probably be trashed and cost at least an arm.
« Reply #9 on: May 13, 2008, 05:42:54 AM »
I'm going to be using a setup out of a ford thunderbird.
-46 Fargo
