August 30, 2008, 12:17:33 AM
|-+  General Category
| |-+  Wanted
| | |-+  power steering pump pulley
Author Topic: power steering pump pulley  (Read 165 times)
jbarker
« on: May 08, 2008, 03:50:58 PM »
Hi fellas-
I need a power steering pump pulley for a Chrysler/Federal style power steering pump.
      I used a backhoe and a length of chain to pull my donor engine out of an untowable 69 Newport that was rotting in a field, and the power steering pump pulley got bent in the process (wonder why?  hammer).
   I tried to use the keyed pulley off my late model saginaw pump, but it is too loose.  I found this one online that I think might work, but the price is pretty steep. http://www.jegs.com/i/March+Performance/655/532/10002/-1/757864%7C10223
Anyways, thanks for any help!
-Jay
smitty72
I'll finish it someday
Re: power steering pump pulley
« Reply #1 on: May 08, 2008, 04:30:32 PM »
when I get home I will look and see if I still have 1 if I do you pay the shipping and its yours
jbarker
« Reply #2 on: May 08, 2008, 05:06:56 PM »
Thanks Smitty!  Let me know what you find.
dusterboy15
« Reply #3 on: May 09, 2008, 03:24:11 AM »
I have one thats on my old setup
jbarker
« Reply #4 on: May 10, 2008, 05:53:23 PM »
Is it for a federal pump?
These pulleys have no keyway in them  They are a press fit.  Does it run true or is it slightly bent?  Let me know what you have and thanks for your reply.  Smitty has been kind enough to look for me, but has not been able to find his yet.
-Jay
Sixpak
« Reply #5 on: May 10, 2008, 07:58:19 PM »
MAKE SURE you get a pulley from the same type of motor as well as the pump. Some of those federal pump pulleys aren't solid; they have like spokes to the center, and different motors had that center part bent in different amounts to make the pulley align with the pulleys on that particular motor. I've been down this road - tried to use a slant 6 federal pulley on a small block and the belt grooves would not line up.
