July 09, 2008, 03:03:16 AM
|-+  General Category
| |-+  Off-Topic
| | |-+  Jaguar rear discs
Author Topic: Jaguar rear discs  (Read 101 times)
mr-ivy
Jaguar rear discs
« on: May 11, 2008, 01:33:00 AM »
I know someone here must work in a brake shop. I have the rear calipers and rotors off my daughter's '02 Jag X Type. I need to know how to compress the caliper piston to get new pads in place. I know usually you can compress them with a large c-clamp. For some reason, that's not workoing. Is there something I'm missing? Thanks for any info. Ivy.
Tiamat
Re: Jaguar rear discs
« Reply #1 on: May 11, 2008, 01:35:05 AM »
Not sure about the Jag but on my wifes honda you screw them back in by turning the piston.
doug 371
« Reply #2 on: May 11, 2008, 01:35:56 AM »
some pistons need to be turned in the bores to compress...is there slots in it that look like u could turn it?
mr-ivy
« Reply #3 on: May 11, 2008, 01:44:44 AM »
Yeah, there's a large hex in the middle (bigger than any allen wrench I have) and a couple of slots at the edge. Does it screw in clockwise or counter clockwise?
Tiamat
« Reply #4 on: May 11, 2008, 01:54:03 AM »
Clockwise usually
Adam
adampietkiewicz@hotmail.com
« Reply #5 on: May 11, 2008, 08:44:27 AM »
Also, on a lot of high end Imports (BMW, Mercedes, etc) I've heard you can cause problems by pushing the calipers back because it pumps fluid back through the abs module or whatever those guys call it. A better idea is to compress the caliper with the bleeder open so it comes out there instead of pushing back through the system, then topping up the fluid when you're done.
Adam
