July 05, 2008, 01:02:04 AM
| | |-+  BBD born this weekend fuel pump question
Author Topic: BBD born this weekend fuel pump question  (Read 219 times)
warthog
« on: May 11, 2008, 06:43:00 PM »
Hey Guys, I fired my 67 Dart 383 this weekend.  The car has a Holley Blue electric fuel pump.   Anyways I was having fuel pressure problems before I got it started.   The pump eventually started working and the motor started but the pressure was swinging up and down from 2 psi to 7 psi and the motor would want to stall.   The pump is new but has sat unused for a quite a few years.  I am not real familiar with these but I was wondering if rebuilding it would take care of it and what kit I need.  Summit shows a Check Valve Kit and a Rotor and Van Kit for it.  Which kit do I want to buy or both?   Thanks for your time.   Dan
lake worth, florida
55robert@bellsouth.net
Re: BBD born this weekend fuel pump question
« Reply #1 on: May 11, 2008, 08:35:16 PM »
take the thing apart and make sure all the vanes are free to move.  use some 400 wet or dry paper with wd-40 and sand them down. they maybe rusty from sitting so long. you can use the same gasket again. also the regulator probably needs a new diapham or cleaned up too.
sunsetdart
us4ever365@hotmail.com
« Reply #2 on: May 12, 2008, 06:02:39 PM »
With the pump sitting unused for years, what bOb said is the way to go. If it had some leftover fuel in it , even remanants of , it turned to varnish and needs a good cleaning.
496dart
« Reply #3 on: May 12, 2008, 11:20:23 PM »
After its cleaned up do the gas can flow test  while you are at it.
ksdartguy
« Reply #4 on: May 13, 2008, 10:39:55 AM »
Also what are you running for a regulator?
The blue is a higher pressure pump.
It has a relief for 14psi so you have to have a reg.
Rick
69 Swinger, 400/499, ported Stealth heads, Crower 262/266d, .686/.696L roller,11 to 1
on E85, 150hp N2O plate, All under hood.
warthog
« Reply #5 on: May 13, 2008, 11:54:02 AM »
Thanks for all the help guys, I do have a regulator on it and a gauge.
