July 09, 2008, 03:26:23 AM
| | |-+  Need to Replace Oil Pump....Not Enough clearance to Remove
Author Topic: Need to Replace Oil Pump....Not Enough clearance to Remove  (Read 200 times)
Pro Street dart
« on: May 12, 2008, 09:40:30 AM »
The oil pump hits into the K-Member at 3/8" out.  If I can raise the drivers side (or whole engine) I can do it. When I  R & R'd my TTi headers both sides on the engine raised easy. Now It won't raise at all. Torque Arm unhooked, both motor mounts unbolted (rubber insulators, not the brackets).  Anybody know what's holding it? The only other thing I had disconnected were the collectors to exhaust.
Any suggestions?
440
TTi 1¾
RB K-Member
Schmacher Mounts
doug 371
Re: Need to Replace Oil Pump....Not Enough clearance to Remove
« Reply #1 on: May 12, 2008, 11:28:30 AM »
is the oil pan touching the k-frame?
lake worth, florida
55robert@bellsouth.net
« Reply #2 on: May 12, 2008, 03:16:32 PM »
those headers wrap around under the torsion bars and are real close to the steering arms, they will probably need to be loosened from the heads.
Draginmopars
« Reply #3 on: May 12, 2008, 04:26:53 PM »
can you take the pump cover off first, Then you might have enough room to get the rest out.?
"Stealth Mode"   83 Shelby Rampage     Ha-Ha Racin   Havin Fun101
VF Coupe
1969 VF Valiant Coupe
« Reply #4 on: May 12, 2008, 07:36:21 PM »
I had some success by dropping the trans mount, supporting with a trolley jack and also undoing your drivers side mount.
Bugger of a job!
"She sips nitro...with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the bitch is born to run! "    Mad Max!!!
FastmOp
« Reply #5 on: May 13, 2008, 12:58:54 PM »
Can you loosen the Kframe bolts and let it hang down a little?
Blvedere
« Reply #6 on: May 13, 2008, 07:16:39 PM »
If you run a scatter shield i'd bet it's hitting the floor boards.
