Topic: The cost of a voltage spike (Read 243 times)
As some of you might know I had electrical problems at the Branson (MECCA) show. It spiked and took out my Pertronics Second Strike box and matching billet distributor, my Viper alarm system, a Sony 180 watt amp and all the light bulbs on the exterior except the front blinker bulbs. I made it back to Denver after buying a stock re-built dizzy from Advance for $48.00. A costly lesson to say the least. Does anyone make a voltage limiter that will sense when it exceeds 15V and instantly shut down the field windings?
them blue mopar ones are constant voltage...only 13.5 though
Got any details on that?
Its Possible to build one, I built one for 5v before to clamp a MAP sensor. You will have to search the internet though, I can't remember where I found it.
Got any details on that? i'll get u a part #
constant output voltage regulator-(quote from parts book) to insure your ignition and electrical systems can provide maximum performance, install a COVR. voltage is held at a constant 13.5 volts as opposed to the production regulaters fluctuation from 11.5 to 13.5. for race applications only P3690731-70 and up P3690732-69 and older cant guarantee anything just an option
