September 07, 2008, 09:50:13 PM
| | |-+  Anyone using a midplate without adding spacers for flexplate?????
Author Topic: Anyone using a midplate without adding spacers for flexplate?????  (Read 157 times)
« on: May 13, 2008, 03:25:11 PM »
...on.0.125   steel midplate.... has anyone used one without adding a flexplate spacer or   shims  to make up the variance?
55robert@bellsouth.net
Re: Anyone using a midplate without adding spacers for flexplate?????
« Reply #1 on: May 13, 2008, 03:38:48 PM »
i reckon when you order your convertor you're suppose to tell them you're using a midplate.
« Reply #2 on: May 13, 2008, 03:48:16 PM »
true true...except i allready have a converter
sunsetdart
us4ever365@hotmail.com
« Reply #3 on: May 13, 2008, 06:24:42 PM »
I have a midplate and had the converter neck made longer. Don't know about using spacers , I would talk to the comapny that made the converter to see what they think.
« Reply #4 on: May 13, 2008, 06:41:46 PM »
I'd imagine some hardened washers - as wide as possible would do the trick.
Steve DeTar
« Reply #5 on: May 13, 2008, 06:58:42 PM »
Somebody sells a steel shim between the crank and flex plate, but I forgot who.
Engine by DeTar
Blvedere
« Reply #6 on: May 13, 2008, 07:09:16 PM »
I always use hard washers to shim the converter . You want the snout to set as deep into the pump as possible.
« Reply #7 on: May 13, 2008, 07:58:18 PM »
My CE midplate came with both 6 and 8 bolt spacers.
« Reply #8 on: May 13, 2008, 09:51:25 PM »
humm thanks  guys. Smiley....  that's what i had figured.....when i originally mocked the engine up in the car  i had  welded on spacers to the flexplate  but then i ended up getting a diferent flexplate...i just didn't like the idea of having loose shims behind so much  hp...so i think i'm just gona weld some new ones onto the converter..... duster
bigtimeauto
Plymouth meeting, PA
« Reply #9 on: May 13, 2008, 10:34:20 PM »
push the converter into the trans all the way, measure the distance, subtract .187 (3/16) then shim as needed. I use hardened washers to make up any space.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
