October 12, 2008, 05:13:52 AM
| | |-+  Sway Bar Mounting point
Author Topic: Sway Bar Mounting point  (Read 169 times)
VF Coupe
1969 VF Valiant Coupe
« on: May 13, 2008, 08:01:48 PM »
I have just picked up a new sway bar but as part of the kit I have to weld a bracket on each of my control arm,s does any have a photo of this so I know where to put it.
Thanks!
"She sips nitro...with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the bitch is born to run! "    Mad Max!!!
Allentown, PA
Re: Sway Bar Mounting point
« Reply #1 on: May 13, 2008, 08:31:32 PM »
check the last pic in the second psots of this thread .. should fix you right up ...  !nanr
http://www.bigblockdart.com/index.php/topic,29452.0.html
bbscamp
Ehm.....B5 Blue am I?
« Reply #2 on: May 13, 2008, 09:40:31 PM »
If its an addco bar for a 73+...the sway bar goes through the K frame, the tabs are welded on near the center of the LCA.  I mocked it up on the bench, marked the LCA, drilled then bolted it, then welded it JUST to be sure!
On my early 64 Valiant, the addco bar mounted under (just to the front) of the K frame.  The angle brackets fit on the lower shock mount bolt.
On the 67-72, the bar will mount under the K frame......but I haven't done one....so I don't know where the bar end link tabs would mount - sorry.
fourspeed
Wisconsin
« Reply #3 on: May 13, 2008, 11:51:35 PM »
My '72 Addco bar mounted to the shock bolts, like your '64. I could never figure out how their suplied hardware was supposed to mount to the k-member. A welder would have been handy back then.
