July 24, 2008, 12:32:47 AM
| | |-+  What the heck anti freeze leak? Help
Author Topic: What the heck anti freeze leak? Help  (Read 264 times)
warthog
« on: May 13, 2008, 09:47:29 PM »
O.k. Guys you all are probably sick of seeing all my post since my bbd sign was started that weekend.  But I went out to the garage tonight and noticed two small puddles of antifreeze under the car at the back of the motor.  I looked for a while and from what I can tell it was seeping out of each rear cylinder on both sides under the headers.   I can only assume that antifreeze is seeping thru the header bolts?  I thought the header bolts were pretty tight but I did get them to turn some.   Is this something that you guys have experienced? I need some input here.  I am kind of freeking out that it something serious but since I have never had a car with headers I figure this might be the problem.  Huh??
Plymouthfan
Re: What the heck anti freeze leak? Help
« Reply #1 on: May 13, 2008, 09:51:38 PM »
Did you put a sealant on the bolts first?
« Reply #2 on: May 13, 2008, 09:53:25 PM »
What's the engine?    Dunno
Saint Paul, MN
« Reply #3 on: May 13, 2008, 10:06:48 PM »
Header bolts will tend to loosen as they go through a few heat cycles. Sealant is always good insurance to make sure they don't leak.
'67 Notchback- 12.88 @ 109mph
440, M1, modified 750 Holley, .509 cam, template ported 906's, ProParts, 3" x-piped mandrel bent exhaust, Spintech's, 3.91 Sure Grip, 3200 stall, SS springs, 1.04" t-bars, RR hood bulge
harryhood
72scamp.com
« Reply #4 on: May 13, 2008, 10:19:28 PM »
I've had the same thing happen a couple of times as well. A little sealant and elbow grease and the leak goes away.
warthog
« Reply #5 on: May 13, 2008, 10:21:01 PM »
Sorry its a 383,  No I didn't know you had to but sealant on those bolts (INSERT warthog is a DUMB ASS).  Just some RTV sealant?  Thanks for the quick replys.
JohnnyfromChicago
« Reply #6 on: May 13, 2008, 10:34:06 PM »
I used anti-seize on mine and it worked, but I think everyone else uses rtv. The first time mine leaked, I got lucky and just enough rust formed to stop the leaks without having to take them out.
chryco
« Reply #7 on: May 13, 2008, 10:39:33 PM »
I used teflon tape , not messy to work with and will take the thermal cycling better.
   Not just for pipe threads !
      Chryco Wink
Hemi Darts Rule !!!!!
blown71duster
« Reply #8 on: May 13, 2008, 10:51:57 PM »
You could always try a bottle of bars leak first, It will seal that type of leak if it isnt real bad
1971 Duster 440  Single turbo
acpat
« Reply #9 on: May 13, 2008, 11:42:29 PM »
bars leak plugs up leaks and the radiator. Leave the can of rat turds alone
67Dart383
« Reply #10 on: May 14, 2008, 01:26:28 AM »
If you don't know, which might be the case since you didn't use a sealant on your bolts! When you pull a header bolt out, your antifreeze is going to come out behine it' So you might want to drain the block before removing header bolts! Good Luck!
dodgeboy
« Reply #11 on: May 14, 2008, 07:49:04 AM »
The problem you have is nothing serious. I had the same problem with mine. Stopped the leak with a product I believe (not sure) was called alumaseal. Experienced parts people will know it when you describe it to them, it is an aluminum based powder that comes in a clear plastic cylinder with a pop off cap. I have used this product before and never experienced it causing any cooling system problems.
Roger
blown71duster
« Reply #12 on: May 14, 2008, 08:13:16 AM »
No, bars is safe to use and will not  plug radiator or heater cores , we have  used it in our shop for years and have used it for header bolt coolant leaks,perfect for that kind of leak
It is factory installed, including chrysler..
http://www.barsleaks.net/barsstory.html
« Reply #13 on: May 14, 2008, 08:20:15 AM »
its just a header bolt leak...no need to pour smag in there... Roll Eyes
plotners@msn.com
« Reply #14 on: May 15, 2008, 01:00:46 AM »
Both end bolt holes on big block heads go into the water jackets.  No need to put additives into your nice, new cooling system.   Replace the end bolts with studs and nuts.  Use a thread sealant and they won't leak.   The studs also help when you're putting the headers and gaskets on...
My Mopars:
'69 Cuda SRT8 6.1 Hemi
'05 Jeep Grand Chickeree 4.7
"3 Hemis, no waiting!"
Dart Guy UK
« Reply #15 on: May 15, 2008, 06:56:40 AM »
Both end bolt holes on big block heads go into the water jackets.  No need to put additives into your nice, new cooling system.   Replace the end bolts with studs with nuts.  Use a sealant and they won't leak.   The studs also help when you're going putting the headers and gaskets on...
Under constuction
1968 Dart Pro street 2dr sedan
440 11.5-, iron koffel max ported heads, crower hyd 530 cam, fenderwells, JW 4200 converter,4 link 8 3/4 4.56 gear with spool &  31x 18.5-15 out back
It will be street leagal and gas is over $10 a gallon
« Reply #16 on: May 15, 2008, 09:48:03 AM »
I'm pretty sure that's what I used to do.
kudah440
kudah440
« Reply #17 on: May 15, 2008, 09:58:36 AM »
using the studs for the 4 corners is good if you have room in your eng bay, but with a bick block sealant has turned out to be better for me in the past.  Nothing like trying to pull the headers off around those studs and not having enough room to get them out...
do watch out for the shooting of water if you pull the bolts though.
Jeremy
69 BCuda 383
71 Duster 440
74 Scamp 340
All in differing states relative to my state of mind
72 Swinger 394/727/8.75
« Reply #18 on: May 15, 2008, 09:37:29 PM »
Hey WARTHOG....Stop being a DumbAss!!! JUST KIDDING! No really!! Im just messing with ya! Sorta....... hammer
