October 13, 2008, 12:55:59 PM
| | |-+  Mopar M1 440 intake, P4532756, anyone heard of this?
Author Topic: Mopar M1 440 intake, P4532756, anyone heard of this?  (Read 340 times)
« on: May 13, 2008, 10:32:23 PM »
I have a Mopar M1 440 intake w/dominator flange, P4532756, anyone heard of this? I can't find any reference to this P/N. I was specifically told that it was a 440 intake that fit stock heads. Anyone got any idea?
andyf
Re: Mopar M1 440 intake, P4532756, anyone heard of this?
« Reply #1 on: May 13, 2008, 11:46:46 PM »
That might be the casting number, not the part number.  Is that a standard width manifold or the extra wide version for the Stage VI heads?  Mopar Performance makes a couple of intakes that look like that for the Stage VI heads, one is a max wedge version and the other fits the standard port size.
« Reply #2 on: May 14, 2008, 12:03:40 AM »
P-number followed by 7 digits are Mopar Performance part numbers. It is cast into the top of the Manifold.
Is there a way I can measure it to determine what it fits, I don't have a 440 to check it on now. What is the deck width on a 440?
andyf
« Reply #3 on: May 14, 2008, 01:33:35 AM »
You just answered the question.  If that is the number that is cast into the intake then it is the casting number, not the part number.
jyrki
« Reply #4 on: May 14, 2008, 02:04:36 AM »
Yes, like stated above, the MP casting numbers also start with P, but are different than the actual part numbers. That intake really seems like a RB intake for raised port Stage VI heads, non MW size. #P4876127
MoPar_or _NoCar
« Reply #5 on: May 14, 2008, 02:06:04 AM »
I don't have a caliper that big here and not sure if this will help but both ends have an ID of 8.75". To many steps to measure and describe and this is a stock 440 cast intake. Can't post pic for some reason?
« Reply #6 on: May 14, 2008, 04:05:48 AM »
yeah that's the intake that i think it is to.. which is a bunch wider then a std 440 intake to mate upto the raised port  stage V1 head without having to use a spacer
Blue
« Reply #7 on: May 14, 2008, 07:25:44 AM »
I agree, the only M1 intakes I have seen with a cast in valley cover have been for stage 6 heads. I seem to remember that when you fit stage 6 heads on a B block, an RB intake bolts straight on. I'm thinking that if what you have there was a B intake for standard port stage 6's, then it should bolt straight up to an RB with stock heads....then again I might not be thinking straight....
« Reply #8 on: May 14, 2008, 08:39:40 AM »
actually ya that is true  and looking at a older mopar catalog  they do show a intake  for the stage 6 heads on a low deck   part# 4529724 for dominator flange{it's just goofy how  the part # and casting #'s are so close but not the same thing?}....so mistery  should be solved   they just don't  offer it anymore since a std 440 intake can bolt onto  a low deck with stage 6 heads......that will be a nice intake  for someone building a   stock port 440 Smiley..sorry for any confusions  Flyboy
Dart Guy UK
« Reply #9 on: May 14, 2008, 08:52:07 AM »
Well done John  Grin
Under constuction
1968 Dart Pro street 2dr sedan
440 11.5-, iron koffel max ported heads, crower hyd 530 cam, fenderwells, JW 4200 converter,4 link 8 3/4 4.56 gear with spool &  31x 18.5-15 out back
It will be street leagal and gas is over $10 a gallon
« Reply #10 on: May 14, 2008, 10:00:21 AM »
actually ya that is true  and looking at a older mopar catolog  they do show a inatake  for the stage 6 heads on a low deck   part# 4529724 for dominator flange{it's just goofy how  the part # and casting #'s are so close but not the same thing?}....so mistery  should be solved   they just don't  offer it anymore since a std 440 inatae can bolt onto  a low deck with stage 6 heads......that will be a nice intake  for someone building a   stock port 440 Smiley..sorry for any confusions  Flyboy
Thanks, the reason I was asking was that I bought this thing from the guy because he said it was for a stock port 440, but when I bought it, I didn't realize that it was a Dominator intake, I have no plans of using this carb, so I am seling it now. Thanks for the help guys.
andyf
« Reply #11 on: May 14, 2008, 04:37:23 PM »
I checked with one of the tech line guys at MP and he said it is a Stage VI intake with standard ports and 4500 carb.  That would make it the P4876127 part number.
« Reply #12 on: May 14, 2008, 05:04:35 PM »
 Frustrated.....ok  how about  we get some measurements of the intake...just to make absolutly sure.....just use a measuring tape......block end rail  end to endon the bottom side....maybe you can also  take a pic   with a std 383 siting upside underit...and just by looking we can determine for sure
« Reply #13 on: May 15, 2008, 09:02:49 PM »
I took some measurements, the rail width is 8 3/4", then I laid a gasket on it, yup the ports are raised, about 5/8". So its definately a -127 intake.  Undecided
I guess I have to cancel my ebay auction and relist it.  Dunno
coyduster
« Reply #14 on: May 16, 2008, 08:21:01 PM »
I just bought one along with some other parts and didn't realize it was for stage VI heads. It is brand new and no good to me.
