Topic: Mopar M1 440 intake, P4532756, anyone heard of this? (Read 348 times)
andyf
That might be the casting number, not the part number. Is that a standard width manifold or the extra wide version for the Stage VI heads? Mopar Performance makes a couple of intakes that look like that for the Stage VI heads, one is a max wedge version and the other fits the standard port size.
P-number followed by 7 digits are Mopar Performance part numbers. It is cast into the top of the Manifold.
Is there a way I can measure it to determine what it fits, I don't have a 440 to check it on now. What is the deck width on a 440?
andyf
You just answered the question. If that is the number that is cast into the intake then it is the casting number, not the part number.
jyrki
Yes, like stated above, the MP casting numbers also start with P, but are different than the actual part numbers. That intake really seems like a RB intake for raised port Stage VI heads, non MW size. #P4876127
MoPar_or _NoCar
I don't have a caliper that big here and not sure if this will help but both ends have an ID of 8.75". To many steps to measure and describe and this is a stock 440 cast intake. Can't post pic for some reason?
yeah that's the intake that i think it is to.. which is a bunch wider then a std 440 intake to mate upto the raised port stage V1 head without having to use a spacer
Blue
I agree, the only M1 intakes I have seen with a cast in valley cover have been for stage 6 heads. I seem to remember that when you fit stage 6 heads on a B block, an RB intake bolts straight on. I'm thinking that if what you have there was a B intake for standard port stage 6's, then it should bolt straight up to an RB with stock heads....then again I might not be thinking straight....
actually ya that is true and looking at a older mopar catalog they do show a intake for the stage 6 heads on a low deck part# 4529724 for dominator flange{it's just goofy how the part # and casting #'s are so close but not the same thing?}....so mistery should be solved they just don't offer it anymore since a std 440 intake can bolt onto a low deck with stage 6 heads......that will be a nice intake for someone building a stock port 440  ..sorry for any confusions Flyboy
Dart Guy UK
Well done John
Under constuction 1968 Dart Pro street 2dr sedan 440 11.5-, iron koffel max ported heads, crower hyd 530 cam, fenderwells, JW 4200 converter,4 link 8 3/4 4.56 gear with spool & 31x 18.5-15 out back It will be street leagal and gas is over $10 a gallon
actually ya that is true and looking at a older mopar catolog they do show a inatake for the stage 6 heads on a low deck part# 4529724 for dominator flange{it's just goofy how the part # and casting #'s are so close but not the same thing?}....so mistery should be solved they just don't offer it anymore since a std 440 inatae can bolt onto a low deck with stage 6 heads......that will be a nice intake for someone building a stock port 440  ..sorry for any confusions Flyboy Thanks, the reason I was asking was that I bought this thing from the guy because he said it was for a stock port 440, but when I bought it, I didn't realize that it was a Dominator intake, I have no plans of using this carb, so I am seling it now. Thanks for the help guys.
andyf
I checked with one of the tech line guys at MP and he said it is a Stage VI intake with standard ports and 4500 carb. That would make it the P4876127 part number.
 .....ok how about we get some measurements of the intake...just to make absolutly sure.....just use a measuring tape......block end rail end to endon the bottom side....maybe you can also take a pic with a std 383 siting upside underit...and just by looking we can determine for sure
I took some measurements, the rail width is 8 3/4", then I laid a gasket on it, yup the ports are raised, about 5/8". So its definately a -127 intake. I guess I have to cancel my ebay auction and relist it.
coyduster
I just bought one along with some other parts and didn't realize it was for stage VI heads. It is brand new and no good to me.
