October 06, 2008, 09:51:42 AM
| | |-+  Removing Torsion Bars
Author Topic: Removing Torsion Bars  (Read 445 times)
VF Coupe
1969 VF Valiant Coupe
« on: May 14, 2008, 03:41:50 AM »
I need to take out my stock slant 6 bars and replace with v 8 ones.
Whats the easiest way to get them out without the proper tool?
I do not care if I cannot use them again.
Thanks!
"She sips nitro...with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the bitch is born to run! "    Mad Max!!!
Re: Removing Torsion Bars
« Reply #1 on: May 14, 2008, 11:01:31 AM »
Without the proper tool the easiest way would be to release the tension on them and take a sawz-all to them. Don't froget to loosen up the LCA pivot pins in the k-member for the new torsion bars.
MoPar_or _NoCar
« Reply #2 on: May 14, 2008, 02:53:01 PM »
Reinstalling, do you have the upper A arms on or off?
Duster440
Blasphemous custom Duster
« Reply #3 on: May 14, 2008, 02:59:09 PM »
Upper arms can be off. The lowers just need to be hanging loose and fancy-free.
You can also remove the bars by unbolting the LCA's and strut rods, remove rear TB clips, and pry LCA rearward.
SRT440DUSTER
« Reply #4 on: May 14, 2008, 09:20:41 PM »
Remove the tension and clamp on a couple pair of visegrips...then smake the visegrips with a hammer..I had both sides out in 10 minutes
2005 SRT-4 (307 fwhp) 12.97 @ 110mph on Street Tires
1972 Duster 440 13.20 on one leg
1970 Coronet 4dr 440 - 11.90
gt
« Reply #5 on: May 17, 2008, 10:31:01 AM »
 agree, if you are not going to use them again.
gt
68 HEMI GTS
« Reply #6 on: May 18, 2008, 09:30:56 AM »
slant six bars work good in a drag car, id use the proper tool to avoid screwing them up. you might find a use for them one day
« Reply #7 on: May 18, 2008, 10:43:35 AM »
Don't forget to take off the retainer clips. There has been post on here where guys have beat the hell out of them before asking the question.
« Reply #8 on: May 18, 2008, 05:15:55 PM »
I once took two pieces of wood and clamped a bench vise around them and beat them out. Worked good and didn't mar the torsion bars.
jomoper
dodgit72@yahoo.com
« Reply #9 on: May 18, 2008, 09:46:16 PM »
You can make a simple and cheap torsion bar removal tool .
Just get the appropriate size u bolts and a scrap piece of angle iron .
drill holes in the angle iron the width of the u bolts.slip the u bolts around the torsion bar and throught the angle iron.
snug the nuts up and wail on the angle iron .
I also wrap the bolts and the suface of the a.iron that touches the T.bar.
One so it does not mar the surface of the Bar and Two to give it some grip.
My 35 year old T.bars came out in three good whacks ! hammer
74swinger
« Reply #10 on: May 18, 2008, 10:10:47 PM »
 agree......you could sell those bars to someone.  I made my bar removal tool (similar to the Mancini tool) for cheap.  (less than three dollars from scrap material.  Then I just whack away     bat
Womanator
Womanator Racing
« Reply #11 on: May 19, 2008, 12:47:06 PM »
Cut the wood in half that the torsion bars come in from Mopar and put them around the bar and use a vise grip to hold them and hit them backwards.No damagewill happen.
72 Swinger 394/727/8.75
« Reply #12 on: May 19, 2008, 10:25:22 PM »
Heck if you can get them out without destroying them I would be interested in them
