Welcome,
. Please
login
or
register
October 13, 2008, 03:44:21 AM
1 Hour
1 Day
1 Week
1 Month
Forever
The BigBlockDart Message Board
Technical
Chassis, Suspension
New Brake Rotor install help!
Pages:
1
Topic: New Brake Rotor install help! (Read 155 times)
VF Coupe
1969 VF Valiant Coupe
on:
May 14, 2008, 03:43:34 AM »
When changing brake rotors I have been told the rotor and the hub need separating.
Is this difficult and what may be the issues?
Thanks!
"She sips nitro...with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the bitch is born to run! " Mad Max!!!
dusterdarryl
Re: New Brake Rotor install help!
Reply #1 on:
May 14, 2008, 04:55:00 AM »
thats right, but its pretty easy to do, you gotta punch the wheel studs out first
sunsetdart
Reply #2 on:
May 14, 2008, 06:55:28 AM »
If you use the punchout method, try using a heavy brass hammer so you don't get a chip flying off into your eye. Using a steel hammer, that can happen. It's also a good idea to wear eye protection using either hammer.
Reply #3 on:
May 14, 2008, 11:02:17 AM »
That depends on whether the rotor/hub are one piece or two.........
Pages:
1
Please select a destination:
General Category
=> Off-Topic
=> Wanted
Technical
=> Engine, Drivetrain
=> Chassis, Suspension
=> Body, Paint, Interior, Wiring
=> Early A-bodies
