September 07, 2008, 12:44:21 AM
| | |-+  need pic`s of holley / kickdown and throttle wire
Author Topic: need pic`s of holley / kickdown and throttle wire  (Read 272 times)
norway_dartsport
norway_dartsport
« on: May 14, 2008, 10:38:14 AM »
need pic`s of holley / kickdown and throttle wire ... cant see how this carburator hooks up with the kickdown asembly .
sunsetdart
us4ever365@hotmail.com
Re: need pic`s of holley / kickdown and throttle wire
« Reply #1 on: May 14, 2008, 06:14:19 PM »
 Jegs sells the bracket that holds the throttle cable and the kickdown. It bolts to the back hole of the carb base. Check Jegs under.....fuel and induction....go to throttle cable....look at Spectre.....I have that one on my Holley and it works fine.
rapom
« Reply #2 on: May 14, 2008, 10:53:31 PM »
 agree Scored mine from Summit. Made by Lokar ? Worked great on my 750 Holley. Also picked up their Throttle and kickdown cable as well. $ not bad , and simple hook up. Good luck with it.
mattq
« Reply #3 on: May 14, 2008, 10:54:43 PM »
Lokar is the bomb may need to modify the gas pedal rod also.  Mine bottomed out before full throttle.
3406pk
« Reply #4 on: May 15, 2008, 12:02:45 AM »
I got the Lokar cables from Mancini Racing.  I have a Holley 870 carb and a 727 trans on smallblock.  The cables went in really slick.  I will take some pictures tomorrow.  You have to cut the outer jacket of cable to right length.  A cutoff wheel on a dremel diegrinder worked really good.
guzzimike
1968 Dart GT (383)
« Reply #5 on: May 15, 2008, 01:50:09 AM »
 agree
Same here...
Had to bent the pedal rod backward (out) about 1".
451 valiant
Ontario, Canada
« Reply #6 on: May 15, 2008, 06:21:48 AM »
This is an AFB carb, but thought it might help, a holley should be simillar.
[/img]
Also here is one with the adapter (which I didn't need so I removed it):
[/img]
norway_dartsport
norway_dartsport
« Reply #7 on: May 15, 2008, 05:26:38 PM »
[/img]
[/img]
looks nice but i have original kick down hardwere and throttle wire ....
451 valiant
Ontario, Canada
« Reply #8 on: May 15, 2008, 07:04:07 PM »
Sorry, I thought you meant the Lokar setup, oh well.
krabysniper
« Reply #9 on: May 15, 2008, 08:17:54 PM »
Here is a pic of a 360 with holley 750 4 barrel with the factory "style" kick down. The slider has to be altered so it applies sooner than it would stock. I can see about getting better pics if you need. I used a small nut and bolt to get the distance right on the slider then marked it, welded it, and ground it out with a die grinder until it was where I needed it.
That One Guy
"What if it was one guy with six guns?"
« Reply #10 on: May 15, 2008, 08:50:01 PM »
what is it you really need?Huh just how it's set up, or do you need the brackets that mount to the intake.
on most holleys, the throttle linkage is on the inside (carb side) of the bracket on the carb, the kick down linkage is on the other side of the bracket (away from carb) then there is usually a washer and a pin to hold it in place on the "rod", then from there the return springs going out, the ones going both ways, one for the kickdown (going towards the firewall) and the ones for the throttle, towards front of car.
"I'm your Huckelberry"                      I need someone to look forward to.
norway_dartsport
norway_dartsport
« Reply #11 on: May 18, 2008, 09:57:50 AM »
thanks every body ... problem solved ... the trottle wire didn`t fit where it should have ( maybe because of my wire angle ) soo i drilled up one of the holes and mounted it there... and i mounted a bolt in the kickdown slider Smiley thanks again Smiley
krabysniper
« Reply #12 on: May 18, 2008, 01:15:51 PM »
MAKE CERTAIN you have the kickdown adjusted properly, if you don't you'll be rebuilding your trans.
