December 05, 2008, 11:35:03 AM
| | |-+  Priming engine with oil
Author Topic: Priming engine with oil  (Read 307 times)
3406pk
« on: May 15, 2008, 12:45:23 AM »
I am about ready to fire the engine in the Duster.  It is a 408 smallblock that was run on the dyno last year.  I read the recent threads on priming the oil.  Since the engine was run so long ago, I want to prime it again.  I will use the priming shaft and turn clockwise.  The question is Should I rotate the engine by wrench while priming?  If I do that, how do I keep track of the distributor/oil pump gear location to camshaft gear to keep everything timed right for distributor?  Need your opinions.  Thanks
Re: Priming engine with oil
« Reply #1 on: May 15, 2008, 01:46:14 AM »
if it was run previously i would just remove the plugs and spin it with the starter untill it build pressure.
then do it again to actually move some of the oil out or into the pockets and pools in the heads and lifter valley.
this of course after changing filter and oil.
but i am a tad on the lazy side.
sunsetdart
us4ever365@hotmail.com
« Reply #2 on: May 15, 2008, 05:47:27 AM »
You don't have to turn the engine when priming. Just put the priming shaft in the pump and turn it till you get oil pressure on the gauge, then your done.
chryco
« Reply #3 on: May 15, 2008, 08:15:10 AM »
 agree  Why throw another variable into it ....the timing.
ksdartguy
« Reply #4 on: May 15, 2008, 08:17:33 AM »
Since it was run previously, I would just prime it without cramking it.
That will pre-lube your brgs.
then when you fire it then you will have instant oil pressure.
3406pk
« Reply #5 on: May 15, 2008, 10:35:17 PM »
Hey Guys, Thanks for the responses.  That sounds good to not rotate engine with dist and shaft out.  I will run with the drill motor and priming shaft to be sure there are no leaks to the mech oil pressure gauge.  Thanks again.
« Reply #6 on: May 16, 2008, 10:30:10 PM »
just a reminder that the valve-train gets zero lube unless the engine spins.
unless it has been modified beyond factory design.
d55dave
« Reply #7 on: May 18, 2008, 03:23:22 AM »
 agree - you need to rotate the crank slowly while spinning the pump clockwise - oil to the top end flows through the crank drillings.
chryco
« Reply #8 on: May 18, 2008, 12:10:46 PM »
However this engine has run , not necessary to turn over .
   Chryco Wink
