October 15, 2008, 05:01:08 PM
| | |-+  BODYWORK ???
Author Topic: BODYWORK ???  (Read 503 times)
dangerdawg
BODYWORK ???
« on: May 15, 2008, 05:46:14 PM »
as i've been doing my own work & watching all the posts you guys have been putting up i'm confused now, not so amazing, really. my car 67 dart gt, was T boned, somehow, just caveing in the dr's door & the front half of the 1/4 panel. after working the metal, sometimes till it kept flexing in & out, had to go back, heat & cool, so it would stay in position, i used Bondo to find high & low spots, & rework metal so i wouldn't need Bondo. well, i also used laquer primer to find high/low spots. that's all i had. sooo, now i just about got it good enuff to use a quality primer sealer, but, have some areas to build up. can i use whatever over the laquer, and will it stay? the last guy who painted it used base/clear, can i use 1 stage if it ever gets that far again? comments & questions all appreciated. someone once said you guys are my car club, & i whole heartedly agree with that statement. thanks for the input.
Re: BODYWORK ???
« Reply #1 on: May 15, 2008, 08:06:47 PM »
If you seal it, it should be fine, but just to be safe, let it sit for a month before you do, so all the solvents can evaporate. I use epoxy prime reduced 20% for a sealer.
Re: BODYWORK ???
« Reply #2 on: May 15, 2008, 09:08:12 PM »
use a ployester finishing putty like "icing" to go over the primer ... "bondo" is meant to adhear to bare metal with 80 grit or rougher scratches.   The finishing putty sands out to a smoother edge as well
dangerdawg
Re: BODYWORK ???
« Reply #3 on: May 16, 2008, 10:13:18 AM »
ok, so i can use the laquer primer & finishing putty to build up, then sealer after, or, high build sandable epoxy primer, then sealer? budget is none exsitent, as i had the laquer primer from another project, that is why i used it. just want to stay within my means. thanks. bodywork really..............is confusing. again, thanks.
dangerdawg
Re: BODYWORK ???
« Reply #4 on: May 16, 2008, 10:17:27 AM »
did i mention budget is none exsistent? that is why i don't have a camera. oh, well.
Go Phillies!
Re: BODYWORK ???
« Reply #5 on: May 16, 2008, 11:48:13 AM »
no laquer primer, use epoxy with a guide coat...........start blockin and you will find all the spots that need attention.........after some filler and or finishing plastic, you can bury it in another coat of epoxy.........
Re: BODYWORK ???
« Reply #6 on: May 16, 2008, 12:30:57 PM »
You can buy a gallon and a half of decent epoxy primer for about $80. Its fairly cheap, cheaper than 15 spray cans of laquer primer.  hammer
dangerdawg
Re: BODYWORK ???
« Reply #7 on: May 16, 2008, 04:55:33 PM »
from who?
dangerdawg
Re: BODYWORK ???
« Reply #8 on: May 16, 2008, 04:57:15 PM »
thnx dubb.
Go Phillies!
Re: BODYWORK ???
« Reply #9 on: May 16, 2008, 06:40:32 PM »
if you can get "u-tech" products local to you, E350 epoxy is user friendly and good quality.......its cheaper than comparable epoxies..... mixes 2:1 with E350 activator
http://www.klinesauto.com/PDFs/April2006Tech/Tech%20-%20U-TECH%20-%20E350%20Epoxy%20Primer%20-%20TDS.pdf
MoPar_or _NoCar
Re: BODYWORK ???
« Reply #10 on: May 16, 2008, 07:47:53 PM »
Get it perfect prior to primer. Filler is cheaper than Primer!
dangerdawg
Re: BODYWORK ???
« Reply #11 on: May 16, 2008, 08:10:56 PM »
hey fly, how's your car coming along?        mopar or no car my feelings exactly.
bbscamp
Ehm.....B5 Blue am I?
Re: BODYWORK ???
« Reply #12 on: May 16, 2008, 09:56:19 PM »
eldubb....do you put filler over roughed up epoxy?  or to grind to bare metal (removing the epoxy).....
Go Phillies!
Re: BODYWORK ???
« Reply #13 on: May 16, 2008, 10:58:27 PM »
 either/or........it dont matter as long as its rough.......my motto: Get it straight before you get it smooth
fender was stripped and coated with epoxy.......i rough any areas in need of straightening with 24 grit.......i like working one big area, rather than a bunch of little spots
Disclamer: this works for me, others may have different methods   Cool
24 grit  (slow, with fresh disc only)
filler.....cheesegrate straight, 2 - 3 coats.......sand 36/40/80 on board or block
finishin plastic with a guidecoat..... sand with 80/100/180 on board or block
bury in epoxy
dangerdawg
Re: BODYWORK ???
« Reply #14 on: May 17, 2008, 09:59:50 AM »
eldubb, need a vacation? why don't  you come to sunny az. and see the Grand Canyon, amongst other things, plenty to see & do out here.  LOL
Go Phillies!
Re: BODYWORK ???
« Reply #15 on: May 17, 2008, 11:06:19 AM »
can i play with your taser?
dangerdawg
Re: BODYWORK ???
« Reply #16 on: May 17, 2008, 05:16:24 PM »
you you you betcha!  drinks
