Topic: A arm problem solver eccentric bushing (Read 639 times)
dart swg.
I ordered this bushing kit for my 72 dart (moog#) K7103 . When i got it the bushing they looked like the stock set of bushing i just put in the A arms. Question , is the bushing supposed to be made offset or is it the bolts with the eccentric lob have more offset made in it .If so where can i get them. The guy at the parts store had no idear what i was talking about. thanks
what are you trying to do? are you having problems with your camber setting?
dart swg.
yes, did front end drum disc conversion. Want to lower car in front . Cannot get enough positive camber.
the bolt hole in the bushing is supposed to be offset.
oldkimmer
....................The more u lower the car, the more pos camber u will have.......kim.......
BIG DOG
Isn't it just the opposite?The lower you go the farther the top of the wheel will tip in which is negative camber........or the lower you go the more the a arms move up which changes the angles of the a arms making the wheels tip out at the top?  On my truck moving the a arms down or raising the truck gave me all kinds of positive camber.I don't know how it works for our cars though!
dart swg.
James, Thats what i thought,the ones they got me were standard bushings.No offset. The lower you put the car the more positive camber you need because the top of the tires lean in towards the engine compartment . Thanks guys Joe
440Ken
A place called "Rare Parts", in Stockton, CA buys up all of Moog's obsolite inventory. They may have what you are looking for.
dart swg.
Thanks guys , I got them through O Reilly. Moog # K7103 Problem solver bushings.
MoPar_or _NoCar
With a higher ride height for pan clearance, will I need the offset bushings?
dart swg.
You shouldn't have a problem at all.It happenes when you lower the car. I'm prostreeten my 72 dart and i want it on the ground. So thats when i ran into the problem. Them bushing fixed it for now till i change the front end to coilovers and a rack.
