Topic: crankcase venting (Read 199 times)
hyperdart
I was wondering if anybody had this delema? I have some pressure in my crankcase as at wot the oil shoots out around the valve cover breather -only on the drivers side. This engine is a 440 c.i. with about 11.30 compression, 5,000 Miles on the motor and JE pistons come with the low friction moly rings....I have an indy top end, with a comp solid roller cam. I have installed a Morroso bolt on valve cover to seal the oil from getting out and an external catch can evacuator with breather. Should i invest in the future, a vacuum pump to give me 0 psi - crankcase pressure? and gain more HP and better ring seal?
acpat
you should have invested in NON low tension rings.
fasttcars
basically you can answer your own question on this one...do you want to gain hp and ring seal by investing in a vacuum pump?
chryco
Try a Vac-U-Pan system , their cheap and fairly easy to install if all you want is 0 in the C/C. You`ll get around 7" vac. with one installed properly. Chryco
Hemi Darts Rule !!!!!
