Topic: brake problem (Read 272 times)
you need to lenghten the pedal rod ...
chop saw it in half, add the amount you need using a bolt cut to lenght and weld it back together ...
GTS Cowboy
Is this a common problem when converting from auto to stick?
 Life begins @ W.O.T.
dartracer
every thing should be the same. I would check the booster and the master cyl. My roadrunner with power brakes has some play in the peddle maybe half an inch.
GTS Cowboy
Thats what I thought Dartracer,everything should go right together. I geuss I have to take it apart and look.  If its easy there's usually a catch...if its a prick to do its usually the right thing  ...YEEHAA!
GTS Cowboy
I still don't know what to do  ! help
